Page 508 of 854 FirstFirst ... 8408458498503504505506507508509510511512513518558608 ... LastLast
Results 7,606 to 7,620 of 12803
  1. #7606
    Trstenik - Thun
    Quote Originally Posted by safm View Post
    Hello everyone.
    This is a real clone of Hex V2 or is a normal Hex Can with a different case?
    https://www.obd2cartool.com/atmega-v...t97asr4gcdkro6
    real hex v2 clone doesn’t exist on the marker,yet
    Sent from my iPad using Tapatalk
  2. #7607
    Trstenik - Thun
    Quote Originally Posted by Roma77 View Post
    Today came 10 boards that I ordered in China according to this scheme))) we will experiment)
    During the week I’ll check and if everything works well, I’ll post here gerber files.
    Attachment 585518
    nice work
  3. #7608
    xoom's Avatar
    Ylakiai
    Here are my gerber files for VCDS that i made long time ago
    And manufactured boards:
    Gerbers Attached:
  4. The Following 2 Users Say Thank You to xoom For This Useful Post:
    Roma77 (11th January, 2019), traxpalicaru (15th May, 2019)
  5. #7609
    Mar 2018
    Quote Originally Posted by xoom View Post
    Gerbers Attached:
    good job 0x44 version, I probably will order a couple of boards for your gerberas, only perhaps I will replace si9200 with tja1050 and si9241 with l9637d, I will have to change the scheme a little bit, 9637 easier and cheaper for me to buy, 1050 has a built-in filter on the can-bus
  6. #7610
    Jul 2016
    Vilnius
    What is the purpose of all this? To me all of this looks like reinventing the bike. Items available in mass production (which they are in this case) will always be cheaper than building something yourself. Will you improve something with your own design? I highly doubt that.
    * MK100
  7. #7611
    Mar 2018
    Quote Originally Posted by hid3 View Post
    It’s not for money)) I don’t know what you are doing, but it’s always a pleasure for a radio amateur to collect something with his own hands and then he is very proud that it works, so it’s a goal to collect something and not to buy something ready.
  8. The Following User Says Thank You to Roma77 For This Useful Post:
    hid3 (11th January, 2019)
  9. #7612
    Top Poster jan4's Avatar
    May 2018
    somewhere in Belgium
    aren't those pcb's more expensive than a complete cable......................
    love the initiative by the way
  10. #7613
    xoom's Avatar
    Ylakiai
    if you want i can send you layout file for sprint layout?
  11. #7614
    Newbie Mrjitter's Avatar
    Dec 2010
    Spain
    Its really neccesary FT232BL with 0x44 interface ??
    Its ok this schema for 0x44 interface ??
  12. The Following User Says Thank You to Mrjitter For This Useful Post:
    tuny (29th January, 2019)
  13. #7615
    Trstenik - Thun
    it will be very nice if you can send sprint layout file
    also if you have few empty PCB i will buy
  14. #7616
    xoom's Avatar
    Ylakiai
    4 boards left at the moment
    Here is Sprint Layout5 file:
  15. The Following 3 Users Say Thank You to xoom For This Useful Post:
    Roma77 (11th January, 2019), traxpalicaru (15th May, 2019), tuny (29th January, 2019)
  16. #7617
    Mar 2018
    Quote Originally Posted by Mrjitter View Post
    Honestly, this is not a very good scheme 0х44, I don’t understand why to put the L7812 and then a 5 volt Zener diode, it is easier to set 7805 if the Zener diode fails the ports of the laptop explode).
  17. #7618
    Jan 2016
    I saw in the past more schemathics named "original"..for 44 and 46 too..
    Only one of them having pin 4 pulled-up external too. Attached..
    See ONLY pin 4 is pulled-up externaly. That make me think is used in logical as 1. pins 1 and 9 not used, so..not connected.
    And another thing: the programm having a button named "OBD II". Is for generic and, as i saw work only for engine for other cars.
    When i am lazzy time to time erase DTC for engine for my old Corsa 2001.
    Is very possible using LLine for this "OBD generic"..
    Is very possible too RT excluded the LLine support in 46 HW. I don't remember when 46 released..If someone having old installers can see in wich version appear HPxxx.bin. But this not explain why LLine circuit still exist.
    Is very possible too, chineses tried extract dump or a person for them..and..extracted truncated or truncated by himself for this motive ("is old, no need")
    I can't download this file, is it removed?
    Elektrik1 amazing work regarding GAL chip. Thank you for your time!
  18. #7619
    Trstenik - Thun
    i briefly checked your pcb and have one question ?
    where is 22pF connected, one side is connected to OSC 7.37MHz and the other side of capacitors is in the air?
  19. #7620
    Dec 2010
    Spain
    i put the zener component, but its a normal diode . Its for apply 5v from usb to all circuit, to program the atmega. Not neccesary 12v from OBD connector .
    I have not usbasp, i have old stk500 program interface. This interface has not 5v to supply atmega.
