I do not think that this is the quality of the soldering ross-tech. I can assume that the owner of the cable took a photo after the repair.
I don't think it has been repaired. But flux should always be washed off in any case.
They build these interfeaces in SA and probably China.
* MK100;
Anyways it is useful to know what the original looks like.
No.
Will not work on new cars.
And x44 is better ?
There's no "better" or "worse". It's just different types. Both are equally good.
* MK100;
and both can not get the new cars?
MQB platform ONLY REAL V2
FoxMulder (16th January, 2019)
Any new "bugs" in 18.9.1 release?
Work with seven point two?
L.E. Tested quickly with 16 ecus autoscan.
Serial still resist. LC work. Must testin more time..
L.L.E. Tested again more like 10 mins. Still working.
Hello guys,
I'm back with some news around my old cable vcds (10.6.4) that i would like to update to a 18.2.0 (english) and 18.2.1 (french),
- Is the 18.2.0 VCDS a stable version or what version do you recommend me ? i would like to be able to run the 18.2.1 french version also , so do you thing that it's possible to use the 2 versions without rewriting the eeprom , please ?
- Do i have to use the loader from the 6.2 / 6.3v of kolimer or can i use the loader from the last package 7.2 v, please, what is the difference, please ?
Thanks in advance for your help.
Details, please..
Wich O.S., and wich cable?
Used on 2 kinds of cables on W7 and W10 64bit. Worked well in autoscan.
One "44" first model with RL and L9637 and one "46" HexV2.
First test is possible to give "Can NR", is an older issue. But the rest..worked well.
I own a real hex v2
Ich besitze ein echtes Hex v2
