Page 512 of 847 FirstFirst ... 12412462502507508509510511512513514515516517522562612 ... LastLast
Results 7,666 to 7,680 of 12704
  1. #7666
    Dec 2018
    Hello again,
    It’ working correctly now.
    Thanks !
  2. #7667
    Jan 2019
    Hi.
    I have this cable . Vcds 18.2.1 and i have multiple rod file missing error .. so cable is pratically unusable.
    What kind of chip does it have ?
    Is it upgradable ?
  3. #7668
    Nov 2015
    home
    Hi ,reflashe thé câble , it will be ok
  4. #7669
    Jan 2019
    Hello. This interface can be repaired? Now its not connecting to CAN due a firmware upgrade from official web site (stupid i know). Thx. P.S. IMAG1024.jpgIMAG1028.jpgP.S. Now i see a modification inside with this red cable. This is a SH interface.
  5. #7670
    EU
    Quote Originally Posted by sahraoui1 View Post
    where do you see atmega162?
  6. #7671
    Jul 2016
    Vilnius
    Wrong message
    * MK100
  7. #7672
    Oct 2017
    Germany
    Quote Originally Posted by Tyrex View Post
    what is happened to this interface? Bad soldering, maybe short circuit.
    Throw it away and buy a new one!
  8. #7673
    Feb 2013
    UK Bristol
    On the 2nd photo right side Yellow element, capacitor....resolder in correct possition
    1st photo. Chip from right side. Pin 20 and 21 have short... it is correct?
    My post helps you? Please Hit Buttons
  9. #7674
    Jan 2019
    I allready buy a new Hex v2 18.9. This old one i try to repair-it just for my curiosity. Bad soldering on old interface is not my work, i buy-it like that.
  10. #7675
    Jan 2019
    Quote Originally Posted by kaalis View Post
    So ? i dont understand...
    Is it flashable or not ? And primary ...Is there a solution to Rod files missing error to keep it in life ?
  11. #7676
    Oct 2017
    Germany
    Quote Originally Posted by igt View Post
    No, it is not updatable, because it has an ARM microcontroller (with non public china firmware inside) instead of Atmega162.
    The best part is: The case incl. torx screws :-)
  12. #7677
    Jan 2019
    Quote Originally Posted by networkers View Post
    Yes, same here. Seems to work fine!
    hi.... work with orignal DRV Version ? wich version u using ?
    my cable works now with 18.2.1 DRV and Loader 7.2
  13. #7678
    Jan 2019
    I have a 10.6 vcds cable.
    I unscrewed it and it's an atmega162V.
    I removed STC chip.
    I soldered PINS from tutorials from above 100% correctly, i checked twice with multimeter. I gave 12V voltage and the LED stays green, or when i dont it blinks red.
    I have a USBASP V2 LC Technology.
    And when i want to program, progisp says "chip enable program error" on both cases.
    I tried a lot of drivers and still nothing.
    Photo with PCB: https://imgur.com/a/4zPAdpP
    Thank you for your time!
  14. #7679
    Mar 2018
    Quote Originally Posted by razvan2003 View Post
    I removed STC chip.
    If you are 100% sure that you are doing everything correctly and you have called up all the contacts and cable at the moment, then the worker thinks that it is erased with ID 1E: 94: 04 on FF FF FF, now it needs to be desoldered and restored through JTAG.
  15. #7680
    Hi Lads
    Just updated my cable to Kolimer 7.2.
    Can i run VCDS 18.9.1 with 7.2 ?
    Is there a test i can run on the cable to check if long coding will work before i actually try ?
