Page 513 of 854 FirstFirst ... 13413463503508509510511512513514515516517518523563613 ... LastLast
Results 7,681 to 7,695 of 12803
  1. #7681
    EU
    Yes, save actual coding and just try. If necessary, restore.
  2. The Following User Says Thank You to kaalis For This Useful Post:
    macwol01 (21st January, 2019)
  3. #7682
    Jan 2019
    Quote Originally Posted by Roma77 View Post
    If you are 100% sure that you are doing everything correctly and you have called up all the contacts and cable at the moment, then the worker thinks that it is erased with ID 1E: 94: 04 on FF FF FF, now it needs to be desoldered and restored through JTAG.
    Can you explain a little more about what i am supposed to do?
    Thank you again!!
  4. #7683
    Jul 2017
    Default Micro-CAN
    Does anyone have photos of the micro-СAN circuit board? What CPU chip is used in it?
  5. #7684
    Quote Originally Posted by kaalis View Post
    If long coding is not working due to the cable and i try it and it messes something up.
    Then how can i restore it with the same cable that messed it up ?
    Has to be another way of testing if long coding will work.
  6. #7685
    EU
    Benchtest identical ecu.
  7. #7686
    Hello everyone,
    I am reading the whole thread and trying to understand all the great information. I have had a few Chinese cables in the past, none of which have had Atmega chip, so I am looking to buy a new one with better hardware that I can keep up to date, however I am confused about the best one to buy and I wondered if someone could help me please?
    I see obd2cartool.com recommended a lot in this thread, but I am confused about the best one to buy;
    https://www.obd2cartool.com/vagcom-1...43ntkn3nen2sn3 - This one I see mentioned as a good choice which can be upgraded
    https://www.obd2cartool.com/atmega-v...43ntkn3nen2sn3 -This one I see has kolimer's name in the listing, so again this is a good choice? I realise this is probably just Hex Can internals in a v2 case
    http://www.obd2cartool.com/vagcom-17...anguage-p-1263 - This one says I can update online with original software and can stay connected to the internet, can I not use internet with the other options?
    The price difference is not that important I just want to make sure I buy the best equipment, but option 3 sounds like the best as I can just update online like original?
  8. #7687
    EU
    choose #2 (fake hex v2), it's voltage regulator doesn't heat up as "previous generation". You can upgrade yourself when it's possible.
  9. The Following User Says Thank You to kaalis For This Useful Post:
    jayooo (22nd January, 2019)
  10. #7688
    Thanks for the reply kaalis, I will go with #2.
    I just have a few more questions (apologies, this is new to me and I have not fully read the whole thread yet) Can internet stay enabled with blocking in the hosts file? Is there a detailed step by step for how to update these within this thread? (Im about 100 pages in so far so I may find it), I have read the info.pdf in the loader download but it is still not 100% clear to me.
    Finally, is bootloader already enabled in fake hex v2? Id like to avoid USBASP if possible.
    Thanks again
  11. #7689
    Dec 2014
    PL
    I had the one from the first link. I have easily updated it from version 18.2.0 EN (I received this version) to 18.9.0 EN and 18.9.0 AKP via USB. I did not pay attention to excessive heat.
  12. The Following User Says Thank You to Mario6 For This Useful Post:
  13. #7690
    EU
    Internet is disabled inside from loader itself, but hosts file will not hurt anyway. Bootloader is unlocked.
    Update? Run newer vcds installation and use newer loader if possible.
  14. The Following User Says Thank You to kaalis For This Useful Post:
  15. #7691
    Great, thanks kaalis and Mario6 for your help, I will make a purchase and look forward to finally owning a cable I can update!
  16. #7692
    Aug 2012
    Brasov
    Quote Originally Posted by silikon21 View Post
    Hi everyone!
    I repaired a couple of VCDS cables in the past mostly cablwes up to VCDS805, but today I got a vcds 908 RL version, It has ben updated via internet so now not working.
    As I read about 50 pages of this topis I understand it is a FT232RL the most difficult one to repair
    here's a picture of PCB:
    Attachment 190548
    now my questions
    If I follow this aminebot tutorial :
    - Reflash Atmega with 908 dump 908.rar.
    - Remove components IC8 , R50 , R51 , D7 as shown on the pic with red arrows.
    - Re-flash FTDI with this dump.
    - Re-flash GAL16V8 (ATF16V8) with this dump.
    - Solder 3 wires as shown on the pic with blue lines.
    - Extract files in this archive to your VCDS directory.
    Is there a new method?
    What tool do i need to reprogram GAL ?
    or can I try this method ? remove the gal :
    Attachment 190550
    Thanks in advance for help!!!!
    Can you please post a link where i can find the files you mention above? Thank you in advance.
  17. #7693
    Quote Originally Posted by takayanagi View Post
    Link please
    Link please
    Here
    https://www.obd2cartool.com/atm-vag-...hipping-p-1566
    But id buy this cheaper and will update to 18.9 with v7 loader
    https://www.obd2cartool.com/vagcom-1...version-p-1266
  18. The Following User Says Thank You to macwol01 For This Useful Post:
    ni88l3r (25th January, 2019)
  19. #7694
    Mar 2018
    Sorry, random post.
  20. #7695
    Feb 2018
    Hi guys, can someone help me?
    I've got a problem with one of my cables. My PC froze and I pulled the cable out, now it doesn't get recognised in Windows.
    I tried to delete drivers and reflash with kolimers tool. It succeeds, but when I try to use the cable after flashing, VCDS cant find it. And it doesn't get recognised by Windows.
    I hope this makes sense
  21. The Following User Says Thank You to IJskonijn For This Useful Post:
    Veex89 (9th March, 2019)
