Page 52 of 854 FirstFirst ... 242474849505152535455565762102152552 ... LastLast
Results 766 to 780 of 12803
  1. #766
    DK Veteran KenshinPT's Avatar
    PT
    Quote Originally Posted by tomasfilip View Post
    make high resolution picture of this eeprom, please
    I am at the office right now.
    I'll post a high resolutionphoto in the end of the afternoon.
    But believe me... I already ordered those EEPROM for spare parts and I rechecked my invoice and it's a Microchip 93C56A. I usually don't do mistakes when reading chips labels
    http://ww1.microchip.com/downloads/e...doc/21794b.pdf
    Another point is if the 93C56A on my cable is not a EEPROM from Microchip and that reference (93C56A) is from other manufacturer - meaning a 16 bit EEPROM. But this is a very remote option.
    Did it help? Push Thanks below
  2. The Following User Says Thank You to KenshinPT For This Useful Post:
    Kinan (10th August, 2019)
  3. #767
    Quote Originally Posted by aminebot View Post
    No , it work only with VCDS lite 1.0 , and it does not work correctly with some computers.
    i will make a loader for 1.1 version when i got free time.
    Hi, have you done this loader?
    Regards, Adam.
  4. #768
    Dec 2010
    Czech Republic
    Quote Originally Posted by KenshinPT View Post
    ok, I believe you, let's see bottom text.. and because on the market is big mess about 93Cx6 memories..
    let's example..
    STMicro
    ST93C46 has ORG pin
    Microchip
    93LC46B - 16bit
    93LC46A - 8bit
    Atmel (big, big mess)
    AT93C46 - org pin
    AT93C46A - 16bit (!)
    AT93C46B - 16 bit
    AT93C56A - org pin
    what I should be interesting how 8bit 2Kbits memory works in 16bit access - maybe should works, just you need twice more space than you want, but for 56(8bits) is OK, there is 2x more than for 46(16bits).. It's hard image how FTDI access different memory (46/56/66)
    I suggest you anyway to follow FTDI recommendation and if you have change to solder 16bit version, do it ..
  5. The Following User Says Thank You to tomasfilip For This Useful Post:
  6. #769
    Hi again,
    You can use this one, too.
    M93S46-WMN6P STMicroelectronics EEPROM
    If no more 93CS46 are in stock anywhere!
  7. #770
    PT
    Quote Originally Posted by Samaelson View Post
    Hi again,
    I ordered a few M93S86 (ST). They have ORG pin, so it can be used a 8 or 16bit.
    But the question here is:
    - Later you pointed for a 16bit only EEPROM saying that it will work.
    - I have a 8bit only EEPROM working good.
    - Tomasfilip used a 16 bit only EEPROM and he can't get it working.
    - FTDI says that FT232BL uses only 16bit
    What a big mess in here...
  8. #771
    PT
    Other thing.
    I have an old fashion VCDS cable with a FTDI232BL and a ATMEGA162V-8AU (8MHz).
    I am going to buy a spare part but at farnell the ATMEGA162V-8AU as been discontinued.
    They only have the 16MHz version. I also so that version in other clone cables.
    But, can I use a ATMEGA162V-16AU for direct replacement of a ATMEGA162V-8AU withou any hardware change (crystal for example)?
  9. #772
    Nov 2010
  10. #773
    Dec 2010
    Other thing.
    Yes you can
    It's only max working ferequrency.
    Darek
  11. #774
    Nov 2010
  12. #775
    Jan 2011
    Constanta, Romania
    hello, has anybody 908.2 romanian dumps?
  13. #776
    Dec 2010
    Czech Republic
    I have as original AT93C46 is 16bit and is working well, but 93LC86-I/SM isn't working because I think clock issue (is less from FTDI than chip is needed)
    in atachement is highres picture of my previous eeprom
  14. #777
    PT
    Now that you posted that picture... mine is a 93C56A from ATMEL. The *A version of Microchip is 8 bit and the *A version of ATMEL is 16bit.
    Problem solved. You should use a 16bit EEPROM
    The one you ordered from Microchip: 93C86A is 8 bit only
    The mistake here was the manufaturer labels.
    ATMEL labels are all wrong... other manufaturer use the same labels:
    A is for 8bit
    B is for 16bit
    C is for both.
    Damn you ATMEL
  15. #778
    Dec 2010
    Czech Republic
    Quote Originally Posted by tr3ce13 View Post
    It works for me, always needs more power to write than to read.
    The 93c46 have any internal conecttion, vcc pin have 4,6v output (whitout connected to anywhere)
    My cable have 6 and 7 93c46 pins (NC) connected to 5v usb-port
    unfortunatelly doesn't works for AT93C46, I have also 4,63V on VCC pin, but always cable is recognized as USB <-> Serial (default when eeprom cannot be recognized).. when I do connetion back, is called as Ross-Tech
    but I can imagine for others manufacturer this aproach will works..
    I bend pin 8 and 7 too (should be NC, but I have on PCB gnd on pin 7)
  16. #779
    Romania
    i have a problem. wen i start vidpidfix.exe gives me the error: can't load ft8u245.dll
  17. #780
    Dec 2010
    Czech Republic
    Quote Originally Posted by dariusddj View Post
    I have WinXP 32bit,working well if is alone in directory.. what kind of operation system you have?
