Page 520 of 854 FirstFirst ... 20420470510515516517518519520521522523524525530570620 ... LastLast
Results 7,786 to 7,800 of 12803
  1. #7786
    Jan 2019
    Tnx @roma77
    +1 Kolimar Cable
  2. #7787
    Newbie lantechnical's Avatar
    Jan 2019
    Greece
    I have a old cable 12.12.3. I will attach some pictures.
    I want to ask if this cable can be updated?
    Thank you.
  3. #7788
    No. Not Atmega inside
  4. #7789
    Apr 2017
    is it safe to use VCDS 18.9.1 v1 (first release) with kolimers VCDSLoader_v7.2 ? or should we stay on the VCDS 18.9.0 ?
  5. #7790
    Feb 2019
    to be safe with both versions-18.9.0 and 18.9.1
  6. #7791
    Quote Originally Posted by Kapten View Post
    Yes, with "V1" (aka 14.01.2019) work well.
  7. #7792
    Mar 2018
    I came across a post of a veteran of this forum about how to create a from dump ft232 - eeprom for 162, but I can’t find this post, if it's not difficult to answer, I would like to know the details, thanks.
  8. #7793
    Feb 2019
    Just got this little cable for my Audi s3 2017; (it's actually written VAG189 on mine)
    https://www.obd2cartool.com/atm-vag-...jav1es87oe3gd2
    was able to use it for a few minutes and after that got a message saying to get a valid license/interface (can't remember)
    Since then, when i do my test I get the CAN Not ready result. I'd flash the cable using VAGCOM_EEWriteLang (without changing anything on the cable)
    But still getting that Not ready CAN status when doing test.
    Can anyone help ?
  9. #7794
    Jul 2016
    Denmark
    mateos11
    Hi i have solution for you canbus to work.
    Remove the 3 pad chip marked on image.
  10. #7795
    Feb 2013
    UK Bristol
    Quote Originally Posted by pingu08 View Post
    Can anyone help ?
    You use kolimer 7.2 loader? Use loader but with eng 18.9.0. And go to option and do TEST, If CABLE and all is ok Activation should back to Activate status.
    Or try use Vag Com HW. And press READ (PRESS WITH CONNECTED PLUG TO 12V) if show you not reapond than you brick atmega162... if show you 0x44 or 0x46. Than bootloader still Life then you can try flashing using VAGCOM_EEWriteLang
    My post helps you? Please Hit Buttons
  11. #7796
    Feb 2019
    Quote Originally Posted by pocinas View Post
    I used the VCDS 18.9.exe that was provided with the cable at first (When I started the software you can see a pop up written VCDS loader 7.0)
    Used the cable for a few moment and got the message/error when I tried to apply a long coding for a modification.
    Since then, I've tried Kolimer 7.1 and 7.2 loader. uninstall VCDS 18.9 and reinstall apparently 18.9 VER 1.0.
    Did flash the cable with Kolimer 7.2 utility but unable to get the CAN bus to respond.
    The cable is still good, as under VagComHW the result is bootloader is available, ''hardware'' is 0x46 and FW is 1.96 or 1.95 if I remember correctly.
    Should I retry flashing the cable ???
  12. #7797
    Feb 2019
    Alright just retry it and all is good....i think i was afraid of breaking something and didn snug the cable well in the obd port....
    Will do my mods tomorrow and come back to you if anything.
    This forum ROCCCKKKKKSSS !!!!!
  13. #7798
    Feb 2019
    Earth
    Quote Originally Posted by sympho View Post
    mateos11
    I think it's a joke, right?
  14. #7799
    Jul 2016
    Denmark
    Quote Originally Posted by vortexo View Post
    No, it worked for me to remove the 3 pad componment
    The small one on left button.
  15. #7800
    Mar 2018
    This TAN38 three-pin chip, the function is electrostatic protection (ESD), it is used for CAN bus static protection. can work without it.
