Page 522 of 846 FirstFirst ... 22422472512517518519520521522523524525526527532572622 ... LastLast
Results 7,816 to 7,830 of 12678
  1. #7816
    Dec 2014
    PL
    I checked 18.9.1 AKP (polish) with V 7.2. "Can" not work.
  2. The Following User Says Thank You to Mario6 For This Useful Post:
    jach0o (3rd May, 2019)
  3. #7817
    Apr 2017
    Quote Originally Posted by hid3 View Post
    After hard working week there will be boom again Crisis and headache....
    hey your pm is full so i quote you insted,
    help me with my cable i get CAN: Not Ready, my cheap aliexpress clone works but this cable i bought from http://www.obd2cartool.com/ is giving me this CAN Not Ready
    mycable
    https://www.digital-kaos.co.uk/forums/showthread.php/99750-VAG-COM-VCDS-EVERYTHING?p=3501756&viewfull=1#post3501756
  4. #7818
    mrjay88's Avatar
    Apr 2018
    UK
    hello all does anybody have vcds 18.9.1 r1 because i need to update my cable 0x46 i have kolimar 7.2 loader i have looked and i cant seem to find it or if some one could point me in the right direction it would be very much appreciated thanks
  5. #7819
    Feb 2013
    UK Bristol
    Quote Originally Posted by Mario6 View Post
    Yeep me too. 18.9.1 AKP (Polish) doesn`t work CAN Not Ready with kolimer 7.2. Not sure earlier version VCDS with 7.2 Loader, but works 17.8.0 with Lolimer loader v2
    Another things.. vcds hex v2. Doesnt work 18.9.1 ENG with kolimer 7.2. The same issue. CAN NOT READY, but partially works with 18.9.0 eng
    Partially means... in example 03-ABS i can't use function BASIC SETTING looks like disabled, another problem is 4 modules example Engine, ABS and 2 cant remember which, vcds show me message like Cant find .ROD file (look picture)
    All was tested with Skoda Citigo 2014
    I have another vcds but is Can-hex and there i just use 17.1.3 and 17.8.0 software with loader kolimer loader v2 and there work all stable without issue.20190211_162015.jpg
    My post helps you? Please Hit Buttons
  6. The Following User Says Thank You to pocinas For This Useful Post:
  7. #7820
    Feb 2013
    UK Bristol
    Quote Originally Posted by pingu08 View Post
    I used the VCDS 18.9.exe that was provided with the cable at first (When I started the software you can see a pop up written VCDS loader 7.0)
    Used the cable for a few moment and got the message/error when I tried to apply a long coding for a modification.
    Since then, I've tried Kolimer 7.1 and 7.2 loader. uninstall VCDS 18.9 and reinstall apparently 18.9 VER 1.0.
    Did flash the cable with Kolimer 7.2 utility but unable to get the CAN bus to respond.
    The cable is still good, as under VagComHW the result is bootloader is available, ''hardware'' is 0x46 and FW is 1.96 or 1.95 if I remember correctly.
    Should I retry flashing the cable ???
    Not think so for Flash, probably the point is version VCDS software and Good Loader
  8. #7821
    EU
    Quote Originally Posted by pocinas View Post
    Picture is too bad quality.
    Does ROD file in balloon has some switched characters compared to UDS_EV directory?
    Also, post a pictures from PCB (remove plastic case). This could be NOT-atmega based cable.
  9. #7822
    Feb 2019
    Hello everyone.
    I am in the need of a new cable after a friend borrowed the computer and accidentally accessed the internet so now my it says my cabel is unregistered.
    I have seen someone talking about HQ clone that you can buy and still be able to access the internet on the computer, i think this will be the way to go so it doesn´t happen again.
    I only see people talk about the cable but no link to this HQ clone.
    I have found two different cables on obd2cartools.com that i am choosing between.
    1: https://www.obd2cartool.com/vagcom-1...anguage-p-1263
    2: https://www.obd2cartool.com/atm-182-...k-cable-p-1561
    The first one looks like it can be a HQ clone since it says it supports internet, and it also supports updates.
    Is the description correct about the fist cable or should i save the money buy the second one instead?
    Pasting links to pictures of the cable i have today.
    https://imgur.com/ywzniRa
    https://imgur.com/2geoB3H
    https://imgur.com/pUFyOrg
    https://imgur.com/y8JTJvb
    https://imgur.com/Xi8NUq8
    I dont have the tools or the knowledge to solder and reprogram my cable.
    Regards Dennis
  10. #7823
    blackpirate's Avatar
    Jun 2009
    @Slarva
    pm me, no need save moneys for new one! i sort out for u free
    prepare team viewer and interface conected to a a car
    cheers
    If freedom is outlawed, only outlaws will have freedom!!!!
  11. #7824
    Dec 2014
    PL
    Slarva
    Read here.You can fix the cable yourself.
    https://www.drive2.ru/l/518948048907273121/
    This one is good too. It can be updated to 18.9.0 EN or other language.
    https://www.obd2cartool.com/vagcom-1...43ntkn3nen2sn3
  12. #7825
    Jul 2016
    Vilnius
    Wow, even Russian sites are full of information how to make HUC work with MY2019 cars,
    I have no doubts that in the next version Eric will make corrections to prevent HUC from working on MY2019 cars (this time for sure!), because the interface hardware is "incompatible" in reality, eh?
    * MK100
  13. The Following 2 Users Say Thank You to hid3 For This Useful Post:
    liviudiaconu (18th February, 2019), Tib82 (28th February, 2019)
  14. #7826
    Feb 2013
    UK Bristol
    Quote Originally Posted by kaalis View Post
    Look photo now
  15. #7827
    EU
    Right, vcds detects it's a clone. These files are in UDS_EV. Compare it symbol by symbol.
    ev_ecm10mpi01104c906020ap*.rod
    Now post pictures of your fake V2 pcb and find the "right" version for this cable. It will not really work with latest.
  16. #7828
    Feb 2019
    Hi everyone, I'm new here.
    Please, can anyone help with VAG-K+CAN interface driver software.
    Last edited by opeoluwa529; 18th February, 2019 at 12:57 PM. Reason: Made a mistake
  17. #7829
    Feb 2019
    can anyone recommend a cable / software bundle of obd2cartool, which works out of the box and with which I can encode my caddy.
    Regards Tuono
  18. #7830
    Jul 2016
    Vilnius
    Cheapest option: http://www.obd2cartool.com/vagcom-16...version-p-1266
    High quality option: http://www.obd2cartool.com/atmega-va...hipping-p-1554
    In either case you will need to do a quick reflash (takes a few minutes, no special tools needed) in order to use latest VCDS and loader
    * MK100
  19. The Following 2 Users Say Thank You to hid3 For This Useful Post:
    bronec10 (12th April, 2019), Tuono (18th February, 2019)
