Page 524 of 854 FirstFirst ... 24424474514519520521522523524525526527528529534574624 ... LastLast
Results 7,846 to 7,860 of 12803
  1. #7846
    Dec 2014
    PL
    Quote Originally Posted by DJAPROG View Post
    524 PAGE
    IF SOMEONE CAN TAKE THE HAND VIA TEAMVIEWER I PAY THE WORK WHAT IS LOGIC
    I meant the previous one. Number "523".
  2. #7847
    Jul 2016
    Vilnius
    Default HEX-V2
    Oops, wrong message, please delete
    * MK100
  3. #7848
    Top Poster razor1199's Avatar
    Feb 2017
    thread goes extremely long, it's hard to read it whole . I've bought cable 17.1.3, somewhere here I've read it's good quality, but on another page I saw almost the same PCB with the same components (both) but they were on other locations on PCB.
    As I saw cable is working with 17.1.3 software without any loader.
    Here are pictures:
    Can you tell me if is this good or sh1tty PCB?
    And can I update it with kolimer's package to 18.2?
    hwtype says it's FW 1.96 and HW 0x46, but it didn't write any info about bootloader
    And one more thing I have forgotten. After update (if possible) can this cable be used with network connection ON?
  4. #7849
    Nov 2015
    No Atmel atmega162 is no good
  5. The Following User Says Thank You to FoxMulder For This Useful Post:
    razor1199 (23rd February, 2019)
  6. #7850
    Mar 2018
    Quote Originally Posted by FoxMulder View Post
    This is why it pays to read whole thread. A little effort always pays off.
  7. #7851
    Feb 2019
    Hello!
    Can you tell me if is this good?
    Actual version 16.8.3 EN+RO
    And can I update it with kolimer's package to 18.9?
    easy or difficult?
    Thank you in advance for your answers!20190224_173408.jpg20190224_173523.jpg20190224_173753.jpg20190224_173725.jpg
  8. #7852
    Jul 2016
    Vilnius
    Hello Sir,
    yes, you can.
    * MK100
  9. The Following User Says Thank You to hid3 For This Useful Post:
    LostAngel (24th February, 2019)
  10. #7853
    Col19's Avatar
    Jan 2019
    France
    Hi friends
    Following the reading of the problem of warming adapters VAG, i wanted to share a nice tip to cool our cables VAG is the job of a friend who shares good end result is the reason for my sharing for DigitalKaos members.
    The idea is to find a heat sink for the LM7805 and the whole card, here is a small tip to make the diagnosis quietly. Enjoy
  11. The Following 3 Users Say Thank You to Col19 For This Useful Post:
    kaalis (25th February, 2019), razor1199 (26th February, 2019), traxpalicaru (5th March, 2019)
  12. #7854
    Jul 2016
    Vilnius
    Holy cow, that's some rocket science. Even R0$$ didn't come up with such idea!
    Why not just buy the "HEX-V2" from OBD2CT shop? It uses only ~45-65 mA and produces zero heat...
    * MK100
  13. #7855
    Col19's Avatar
    Jan 2019
    France
    Hi hid3, because i also have this cable and I want to use it the HexV2 (Aliex) i have has a problem with the timer, it can freeze the PC anytime, i think I'll follow your advice and try the cable you advise to see the difference.
    I do not know if it would be possible and useful to add an eeprom memory chip for the 162 ?
    Thanks for the advice.
    Greeting.
  14. #7856
    Dec 2016
    Vilnius, Lithuania
    Just use switching dc dc converter from ali for 30 cents, with no heat dissipated... Pinout compatible to L7805
  15. The Following User Says Thank You to Elektrik1 For This Useful Post:
    vortexo (25th February, 2019)
  16. #7857
    Jul 2016
    Vilnius
    Col, if you installed the heatsink, I think it should have covered the entire metal surface of the voltage regulator for better heat dissipation.
    Also, you should have used either thermal paste or thermal pads/tape for better heat conductivity between the voltage regulator and the heatsink.
    * MK100
  17. #7858
    Quote Originally Posted by Elektrik1 View Post
    Link for this? I only another converters find. And not at .3USD
    Thank you
  18. #7859
    Mar 2018
    Привет, 0,55 $ https://sale.aliexpress.com/ru/__pc/...aff_trace_key= e7a8cc20637f4ff390ecb233c07ef2a9-1551088932166-05049-YFAI6ub & TERMINAL_ID = cf806e3f0d144be9833fcba35b2cf916
  19. The Following User Says Thank You to Roma77 For This Useful Post:
    liviudiaconu (25th February, 2019)
  20. #7860
    Nov 2015
    And this :
    € 1,43 20%OFF | 5 Watt 6,5-40 V zu 5 V DC DC Converter Step-Down Buck Modul spannungsregler Direkt ersetzen TO-220 L7805 LM7805 LDO IC
    https://s.click.aliexpress.com/e/cMqhtRhP
