Why doesn't everyone read the document inside the pack? It has got ALL the information covered there
* MK100;
jan4 (8th March, 2019), litllevill (8th March, 2019), Mario6 (9th March, 2019)
vzinic (8th March, 2019)
Is K-Line used in MQB 2019+ models or CAN only?
I think communication only takes place on CAN in MQB 2019+ cars models!
I think communication only takes place on CAN in MQB 2019+ models
Hid3 said very well; read the document attached in archive.
And yes, this is the chip recomended to be desoldered. Not mandatory, is sufficient to cut the copper line like in document. But i RECOMMEND to desolder that chip if is possible. And that second reseter too. Like in photo
kaalis (8th March, 2019), litllevill (8th March, 2019), Mario6 (9th March, 2019)
Mate, you just wasted your money twice. The pinouts between NEC and ATmega162 are different![]()
* MK100;
Example of good interface:
http://www.obd2cartool.com/vagcom-16...version-p-1266
http://www.obd2cartool.com/atmega-va...hipping-p-1554
Hey guys.
I've recieved today VCDS "HEX-V2" from AliExpress but I have a weird issue..
Device cannot be connected to PC with cable longer than 40cm.. yeah that's weird..
Used cable which came with device and it shows as "Ross-Tech HEX or KEY USB Interface" but with error in Device Manager "This device cannot start (Code 10)" or as Unknown USB Device (Device Descriptor Request Failed)..
Tried different USB cables (longer than 40cm) and still nothing..
but short cable (about 40cm which I've got with arduino clone) = no problem, also succefuly flashed 1.96 flash without any problems (detected as 0x46 with Bootloader Enabled), connected to vehicle (definietly cable is too short for normal usage) without any issues.
Anyone got idea what is going on?
Allright, then where I can get good - working drivers?
meciu (14th March, 2019)
ok, dispute opened with trader.
Contact between laptop and device is perfect, even with cable from vcds - arduino and midi controller works without any issues.
So device itself or firmware or drivers are bad.. but still I don't understand why vcds works with shorter cable![]()
Will Vag Tacho 5.0 can find Pin Codes for this models:
Golf MK6 2012
Seat Leon 2008
Thanks.
