35 days later someone will come here, post pics of HEX-V2 with really bad quality soldering work on the PCB and ask "why the drivers are not detected"![]()
* MK100;
Gyula84 (24th March, 2019), heshamzn (22nd March, 2019), liviudiaconu (22nd March, 2019)
Do some homework: scroll up 5-6 posts and see if you can solve the riddle.
* MK100;
heshamzn (23rd March, 2019)
i saw it but now new problem Can not ready although it was ready before i tested always on my car and it was ready all the time and i could make auto scan now i changed the win to 32 bit and try some programs like can commander and didin't work and install vcp some play around then i install vcds latest it gives me can not ready ??? what the ??
i reflash it again and again no use can not ready what happend do i need to install fresh windows to clear the programs also i installed odis
Got every thing ok again and got Can Ok again the reason for this problem was the latest version which i downloaded yesterday from the ross tech site that was the problem who got link to old latest version that work ok ??
Don't use the latest vcds from the ross tech site they did some thing there that disable the can and make it not ready
Hi all,please help me with this hex v2 to program with 18.9,thanks.
Trimis de pe al meu EML-L29 folosind Tapatalk
I think it is China-type hardware, the poor quality clone that can not be used with the Kolimar Loader! I do not see ATMEGA 162!Compare your clone with the images here, you will see by yourself what the differences are!
https://www.digital-kaos.co.uk/forum...=1#post3504897
litllevill (25th March, 2019)
Hi Everybody!
I have found this site searching for info about my VCDS 11.11.5 why she is not showing some engine data showed by newer version (17....)
I found you guys and you make me very happy!!!
Many THANKS to @kolimer for his support!
So, after reading 4 and more days this thread I have made update (even if I did not planned to do today) to my interface and VCDS.
Even my interface was working OK I was searching for better solution.
I found here link (with picture guide how to do it):
https://www.drive2.ru/l/518948048907273121/
Downloaded VCDSLoader v5.1 and follow guide written by elpaso544 (many thanks to him as well if he is present here).
First I checked my chips:
ATMEGA162 16AU 1236H; ATF16V8BQL - 15SU; FT232BL 731-1; MCP2515; MCP2551; ATMLH236; Even If I am not sure which fuctions they are performing
I need to mention also the seller from BiH (ABdija........ Sarajevo) who sold me this excellent interface few years ago and worked all the time without any problem (many thanks to him as well if he is registered here and reading this).
Checked my version:
Checked HW version:
To be continued in next post
Checked VID an PID data:
Corrected PID data from FA24 to FA20 into VAGCOM_EEWriteLang program
Followed all instructions as elpaso544 posted and there is result:
Very easy update, only through USB and connected to car
One question, can I update it in same way for newer version (18...), without using programmer?
Thanks for all your posts here, they are very useful!!
Use the loader on every version of \ / (ds you install.) Search to download Loader 7.2 for older versions of \ / (ds! I do not guarantee that it works perfectly on the latest version!
Novica (26th March, 2019)
Thanks for suggestion, for now I will use this version. It is ok for my car (Audi 2.0 tdi 2011 year), as I am using diagnostic tool mostly for me. I was hoping that I will get Long coding help for recently retrofitted 4C module (for tire pressure control modul 7K6 option - indirect type) but this module is still unknown for vcds, never mind I get synchronization data in address 01 - enginewhich I could not find on old version.
I don't think that was necessary
I kept FA24 in place and everything worked.
Any pictures with how you soldered the wires to your PCB/chips?
Regarding VAGCOM_HWType.exe, I think you are not using the latest version, it should display a 4th row with info about Bootloader status, I have attached a picture and the latest version
ecufix (30th January, 2021)
