Page 544 of 847 FirstFirst ... 44444494534539540541542543544545546547548549554594644 ... LastLast
Results 8,146 to 8,160 of 12705
  1. #8146
    Mar 2019
    Quote Originally Posted by Roma77 View Post
    we are talking about raising the hood for diagnosis (Toureg, Q7 and so on 2017-19 )
    sorry, not sure what that means
  2. #8147
    Mar 2018
    Quote Originally Posted by bg17aw View Post
    I will try to explain, but it seems that because of a bad translation, not everyone understands me. Some cars of 2017-2019 year can not be diagnosed normally until you open the hood, it turned out after connecting the VCP(vag can pro) there is a hint OPEN PLEASE THE HOOD FOR DIAGNOSTICS. After opening the hood vcd$ worked well with such cars.
    I think that the sensor of the closed hood does not allow the 19th unit (CAN) to switch to the diagnostic mode.
    This also applies to vehicles in which the automatic locking mode is activated when the driver's door is closed or if the key is inserted in the ignition for door diagnostics should be unlocked.
  3. The Following 2 Users Say Thank You to Roma77 For This Useful Post:
    bronec10 (21st April, 2019), muscles1960 (20th April, 2019)
  4. #8148
    Apr 2019
    Hey Guys,
    I bought a cable from Aliexpress a while back. I couldn't get it to work with the stock firmware it came with.
    Somewhere else online I found VCDSLoader_v2. I flashed the firmware and the cable started working.
    However, the cable is very flaky. It works for a few seconds and I can get a single scan or sometimes no scans done before I start getting comunication errors. Unplugging and plugging the USB cable back in gets me back where it may work or may not work.
    Wondering if this is a hardware issue or if there's anything I can do to improve the reliability of the cable.
    I will try the latest VCDSLoader and see if that helps.
    Thanks!
  5. #8149
    Jul 2016
    Vilnius
    Looks like it's got fake FTDI chip along with fake MCP's... Nothing unusual for a cable from Aliexpress, you get what you pay for.
    * MK100
  6. The Following User Says Thank You to hid3 For This Useful Post:
    bubsterboo (21st April, 2019)
  7. #8150
    Jul 2018
    I received the package after 18 days "18 day The item has been delivered successfully"
    I ordered at the recommendation of a user here on the forum and I am very grateful
    I want to thank her for all your help,this gentleman is very good so thank you
  8. #8151
    Apr 2019
    Quote Originally Posted by hid3 View Post
    Okay. When I plug it into my linux computer i get kernel USB communication errors. I guess it must indeed be a fake dodgy FTDI chip.
    I've ordered the recommended one from obd2cartool. So hopefully that arrives soon and I can have a reliable cable.
    Out of curiosity. How can you tell it's a fake FTDI? I know that's common, and it seems to be the cause of my problems, so I don't doubt it.
    The FTDI chip does have markings on it. But they're not very pronounced.
    Thanks!
    Edit: Comparing the markings to an FTDI chip on my BUS pirate it's definitely not the same. Yeah must be fake.
  9. #8152
    Sep 2018
    Mar 2018
    Quote Originally Posted by predki View Post
    definitely photo 1, photo 2 bad cable (resistor assembly instead of logic and transistors instead of microcircuits along K L lines)
  11. The Following 2 Users Say Thank You to Roma77 For This Useful Post:
    bronec10 (25th April, 2019), kaalis (21st April, 2019)
  12. #8154
    Apr 2019
    Quote Originally Posted by bubsterboo View Post
    Thanks!
    I replaced the FTDI chip with a genuine one from a uart board i had lying around. Flashed the FTDI chip and the Atmega and now HWType and EEWriteLange work and 18.9.0 works reliably too!
    Thanks for the help!
  13. #8155
    Dec 2018
    Hey, been using \/AG189 cable from obd2cartool. And recently when I connect cable to my pc it doesn't work anymore, in device manager i get Unknown USB device (Device descriptor request failed). Any ideas?
  14. #8156
    Feb 2013
    Let.s repeat what many other s allready write on this topic: ad some pics with your pcb and then share your problems. We can not guess what is inside your cable...
  15. #8157
    Jul 2016
    Vilnius
    First thing, use multimeter to make sure each and every wire of USB is still intact and not broken
    * MK100
  16. #8158
    Sep 2018
    witaj, gdy uruchamiasz vcds przez program ładujący coś takiegoIMG_20190422_173357.jpg
  17. #8159
    Dec 2018
    My bad. Here are the photos. Thanks
  18. #8160
    Mar 2018
    predki Is the program on drive C? what windows?
    Have you solved the problem with the chip or is it a different cable?
