Page 555 of 854 FirstFirst ... 55455505545550551552553554555556557558559560565605655 ... LastLast
Results 8,311 to 8,325 of 12803
  1. #8311
    Mar 2018
    Quote Originally Posted by igt View Post
    Oh Thank You Roma77!! This is a very useful answer !! Luckily your answered in this intelligent way or i will be lost!
    First of all read my post , i think you don't speak English very well because your reply is hilarious..
    I know perfectly that orignal one are the best cable with ''virtually'' no problems .
    I provided two cable links and an ''Or'' choice.. pretty easy to understand...
    The answer corresponds to the question, which question is this and the answer.
    If you do not know what to buy - buy the original.
    These links are for those who know what to buy.
    Read a few pages back, everything is written.
    Do not be lazy.
    Good luck.
  2. #8312
    Jan 2019
    Thumbs up
    Quote Originally Posted by RiHard View Post
    The first link cable will be end-to-end for your car. It makes sense to buy the second link option 1 without additional, it will be even cheaper
    Thank you RiHard… ''This'' IS a smart advice
  3. #8313
    May 2019
    I’m using 18.2 vcds dutch, with loader 7.2
    However the antivirus is giving the warning that the loader contains a high risk virus.
    Is there another way to get this fixed or is this a fake virus warning?
  4. #8314
    Apr 2018
    Quote Originally Posted by kolbi7 View Post
    Yeah, I see Anybody have 18.9.0 HGJ installer?
    Check your PMs
  5. #8315
    Apr 2018
    Quote Originally Posted by Barregaander View Post
    If you get it from a link on this site, believe me it's virus free, so the warning is fake
    Simply just add the L0ad3r file or the whole directory into the antivirus exclusion list.
  6. #8316
    Feb 2019
    RUSSIA
    Hello! It seems to be looking for, but not found. Who can tell why you need a Y 5FAQ chip? What task does he perform?
  7. #8317
    Is for "pairing" china soft with cable. Not needed in K0l1mer version.
  8. The Following User Says Thank You to liviudiaconu For This Useful Post:
    RiHard (20th May, 2019)
  9. #8318
    Jul 2016
    Vilnius
    Be sure to remove both jumpers (J1 & J5) to power down that chip. This is also covered in Info.pdf
    * MK100
  10. The Following User Says Thank You to hid3 For This Useful Post:
  11. #8319
    Feb 2019
    RUSSIA
    So, for statistics, suddenly someone will be interested. This problem was made by the combination of VCDS RUS 18.2.1 + Loader 7.0
    The problem has already been solved, I do not need help )
  12. #8320
    Jul 2015
    Quote Originally Posted by mikroel View Post
    if somebody need here is full schematic ,both version ,with transceivers and transistors,
    versions with 16V8BQL and Ft232BM
    of course password after given Thanks and Rep.
    Thank's!
    Inviato dal mio KT107 utilizzando Tapatalk
  13. #8321
    Apr 2019
  14. #8322
    May 2019
    I bought a cable on eBay a while back and am just now getting around to really trying to use it. It looks to be the same as option 2 from the VIP link here, I checked my chips against the pictures and it matches exactly. I cannot get it to work right. The listing said it was for V18.2. So I tried it with 18.2 and the VCDS Loader provided, but had no luck. I managed to get ahold of V6 of Kolimer's loader and the dll. So I tried that with 18.2. I have gotten the test to work, and it shows activated. However I get communication errors on everything I try to do. I ran VAGCom HWType and got back that I have firmware 1.96 and hardware 0x46. I'm not sure where to go from here, but I am thinking I may be using the wrong software version. I am reading through as many posts as I can, so if I find a solution before someone responds I will let you know.
  15. #8323
    May 2019
    try downloading the package from this post, its v 18.9.1r1 and loader v7.2
    https://www.digital-kaos.co.uk/forum...=1#post3561446
    then follow the info.pdf in the loader folders to re-flash the cable and restore the firmware. it worked for my cable, i originally had similar problems when the CD delivered with my cable was unreadable. Dont forget to move the VCDSloader.exe file into the VCDS directory and always run that instead of the original VCDS.exe that gets installed by the VCDS installer package.
  16. The Following User Says Thank You to tinyredpostbox For This Useful Post:
    TDISportwagen (25th May, 2019)
  17. #8324
    Mar 2019
    Anyone could share a link for VCDS-ROJ 18.9.0 and possibly 18.9.1 (the 18.9.1 that works?)
  18. #8325
    EU
    There is only 1x 18.9.1 ROJ released. If you are asking for ENG or any other language then be more specific.
    Don't make this topic artificially longer.
    https://www70.zippyshare.com/v/QUp8MZcG/file.html
    VCDS-AER-18021-Installer-20180622.exe
    VCDS-AER-18090-Installer-20181218.exe
    VCDS-AER-18091-Installer-20190215.exe
    VCDS-AIB-18090-Installer-20181017.exe
    VCDS-AIB-18090-Installer-20181219.exe
    VCDS-AIB-18091-Installer-20190215.exe
    VCDS-AIB-18091-Installer-20190517.exe
    VCDS-AIB-18091-Installer-20190520.exe
    VCDS-AKP-18021-Installer-20180430.exe
    VCDS-AKP-18090-Installer-20181107.exe
    VCDS-AKP-18091-Installer-20190204.exe
    VCDS-Beta-19.1.2-Installer-20190211.exe
    VCDS-Beta-19.4.0-Installer-20190502.exe
    VCDS-DRV-18090-Installer-20181005.exe
    VCDS-DRV-18090-Installer-20181017.exe
    VCDS-DRV-18090-Installer-20181219.exe
    VCDS-DRV-18091-Installer-20190215.exe
    VCDS-DRV-18091-Installer-20190517.exe
    VCDS-DRV-18091-Installer-20190520.exe
    VCDS-EST-18090-Installer-v1.exe
    VCDS-FRM-18090-Installer-20181001.exe
    VCDS-FRM-18090-Installer-20181019.exe
    VCDS-FRM-18091-Installer-20190125.exe
    VCDS-HGJ-18090-Installer-20181005.exe
    VCDS-HGJ-18090-Installer-20181218.exe
    VCDS-HGJ-18091-Installer-20190215.exe
    VCDS-HZH-18021-Installer-20180904.exe
    VCDS-ITT-18090-Installer-v1.exe
    VCDS-MFT-18090-Installer-20181005.exe
    VCDS-MFT-18090-Installer-20181218.exe
    VCDS-MFT-18091-Installer-20190215.exe
    VCDS-MFT-18091-Installer-20190520.exe
    VCDS-NEZ-18090-Installer-20181005.exe
    VCDS-NEZ-18091-Installer-20190130.exe
    VCDS-NEZ-18091-Installer-20190203.exe
    VCDS-PCI-18090-Installer-20181005.exe
    VCDS-PCI-18090-Installer-20181017.exe
    VCDS-PCI-18090-Installer-20181219.exe
    VCDS-PCI-18091-Installer-20190215.exe
    VCDS-PCI-18091-Installer-20190517.exe
    VCDS-PCI-18091-Installer-20190520.exe
    VCDS-PRI-17081-Installer-20171211.exe
    VCDS-PTT-18090-Installer-v1.exe
    VCDS-Release-18.9.0-Installer-20180930.exe
    VCDS-Release-18.9.0-Installer-20181001.exe
    VCDS-Release-18.9.0-Installer-20181018.exe
    VCDS-Release-18.9.0-Installer-20181025.exe
    VCDS-Release-18.9.1-Installer-20190114.exe
    VCDS-Release-18.9.1-Installer-20190125.exe
    VCDS-Release-19.6.0-Installer-20190531.exe
    VCDS-ROJ-18090-Installer-20181005.exe
    VCDS-ROJ-18090-Installer-20181218.exe
    VCDS-ROJ-18091-Installer-20190215.exe
    VCDS-RUS-18021-Installer-20180802.exe
    VCDS-RUS-18090-Installer-20181214.exe
    VCDS-ZHS-18090-Installer-20181006.exe
    VCDS-ZHS-18090-Installer-20181029.exe
    VCDS-ZHS-18091-Installer-20190320.exe
    VCDS-ZHT-18090-Installer-20181006.exe
    VCDS-ZHT-18090-Installer-20181029.exe
    VCDS-ZHT-18091-Installer-20190320.exe
  19. The Following 3 Users Say Thank You to kaalis For This Useful Post:
    Gyula84 (28th May, 2019), Roma77 (28th May, 2019), Tib82 (30th May, 2019)
