Page 556 of 854 FirstFirst ... 56456506546551552553554555556557558559560561566606656 ... LastLast
Results 8,326 to 8,340 of 12803
  1. #8326
    Jan 2019
    What about xtool vag401 scanner tool ?
  2. #8327
    May 2019
    Thanks for your help! I was actually going to do this, but @hid3 helped me get it sorted much more quickly than I probably could have myself.
    I really appreciate the prompt support from you guys. This forum will surely be a valuable resource.
    Quote Originally Posted by tinyredpostbox View Post
    try downloading the package from this post, its v 18.9.1r1 and loader v7.2
    https://www.digital-kaos.co.uk/forum...=1#post3561446
    then follow the info.pdf in the loader folders to re-flash the cable and restore the firmware. it worked for my cable, i originally had similar problems when the CD delivered with my cable was unreadable. Dont forget to move the VCDSloader.exe file into the VCDS directory and always run that instead of the original VCDS.exe that gets installed by the VCDS installer package.
  3. #8328
    can somebody confirm that the actual HEX-V2 china clones works with new >=2018 cars?
    The new protocol is CAN-FD and the CAN-Transciever in my cable is a ATA6561 IC with FD-Support and I still wonder why the CAN-Controller on my cable is always the old MCP2515 and not the new MCP2517FD.
    https://www.elektormagazine.com/news...ible-data-rate
    Regards,
    Jackson
  4. #8329
    For now no HEX-V2 clones.
    Only classic HEX-USB+CAN in V2 looks case. With variable quality.
    HEX-USB+CAN works on new cars, but is not possible connection to few controllers.
  5. #8330
    Yes, that what I mean. For a few weeks I had a Q7 in my workshop and with my old hardware cable I can't access all ECU's. Then I bought me a new HEX-V2 clone to solve the problem. Unfortunately now I have the new cable but no new car still available to test it...
    So if your info is correct I could have saved myself the purchase?
  6. #8331
    May 2018
    Brazil
    Dears Friends,
    I am a member of this group, I confess that I have read all the posts of this topic since the first and this time I need a help: A friend has a generic cable and is not with Bootloader enabled. I have the USBASP recorder, however I need the help of the expert friends to guide me where I should connect the pins.
    I already made sure that this is a 0x46 hardware version and FTDI but I could not identify where to connect each pin one.
    Thank you very much for your time in helping me.
  7. #8332
    Feb 2013
    First condition to update/repair your cable is to have ATMEGA on PCB. I see no Atmega there, so stop looking for pinout. You have ARM based model so, if it is working use it as long as you can, if not see link(few page back) where you can buy a new one, be sure this time you get one with Atmega.
  8. The Following User Says Thank You to alexm1 For This Useful Post:
    pablobrsp (28th May, 2019)
  9. #8333
    EU
    Did you notice atleast one post about requirement of atmega162?
  10. The Following User Says Thank You to kaalis For This Useful Post:
  11. #8334
    May 2018
    Brazil
    I bought a new one. It´s damages and blocked. Thank you very much,
  12. #8335
    Oct 2016
    Can anyone explain "Not the procedure" but the numbers, what do they mean while doing Basic Settings for 02E + 0AM DSG "AUTO" ?
    Example:
    062
    values may report: [18 | 18 | .285 | .24]
  13. #8336
    Mar 2018
    Quote Originally Posted by hid3 View Post
    Hello dear DK members and VAG lovers,
    just wanted to let everyone know that OBD2CarTool shop really cares about us and now they have become even better!
    Besides the fact that they offer VIP price for interfaces for us, they also started offering a possibility to order USBASP programmer - so now you can get all the required stuff in once package with quick delivery! Personally I think it's the best deal you can ever get.
    Here's the link: https://www.obd2cartool.com/vip-link...86o4so84i9m7r7
    Pay attention there are two Packages - Classic and "HEX-V2" interfaces as well there are two options - with USBASP programmer or without it.
    Enjoy!
    I will supplement the message with drivers for a programmer with a digital signature, Windows XP, 7,8,10 32-64.
  14. The Following 5 Users Say Thank You to Roma77 For This Useful Post:
    edoc72 (29th May, 2019), hid3 (29th May, 2019), jakuza (30th May, 2019), pablobrsp (29th May, 2019), rak183 (30th May, 2019)
  15. #8337
    Jun 2016
    Gandia
    Hola,
    Hi I have a cable vcds 17, I would like to know with V17.1.3 in English, my question is? what version can I update and if I can in Spanish with this cable, thank you very much for this great work that you do, a greetinghe aquí un cable vcds 17, me gustaría saber con V17.1.3 en inglés, mi pregunta es? ¿Qué puedo hacer? ¿Cómo puedo decir? ¿Cómo puedo saberlo? Con este cable, muchas gracias por Este gran trabajo, hace un saludo
    de Hola, cable VCD ONU TENGO 17, me gustaria saberlo con V17.1.3 En español, MI PREGUNTA ES ¿La ? Con este cable, muchas gracias por este gran trabajo que hacen, un saludo. Hola, tengo un cable vcds 17, me gustaría saber con V17.1.3 en inglés, mi pregunta es? Con este cable, muchas gracias por este gran trabajo que hacen, un saludo.
  16. #8338
    Jul 2016
    Vilnius
    You cannot update this cable to any version.
    * MK100
  17. #8339
    Jun 2016
    Gandia
    Thank you, I have seen the offer, I would opt for it, it seems to be the best and cheapest option
  18. #8340
    Thanks for sharing
