Page 564 of 847 FirstFirst ... 64464514554559560561562563564565566567568569574614664 ... LastLast
Results 8,446 to 8,460 of 12704
  1. #8446
    Jan 2017
    Quote Originally Posted by alexm1 View Post
    Can you upload in a different place, this link does not work...well it works but when hit Download nothing happens..
    Reupload https://www.sendspace.com/file/3bvb8s
  2. The Following 4 Users Say Thank You to engycz For This Useful Post:
    alexm1 (13th June, 2019), Col19 (25th June, 2019), jakuza (13th June, 2019), pablobrsp (13th June, 2019)
  3. #8447
    Sep 2016
    Quote Originally Posted by BASi77 View Post
    Obviously, in the second case there was no response to the request during the timeout.
    Here in the absence of an answer and the whole problem, so this version does not work stably
  4. #8448
    May 2011
  5. The Following 4 Users Say Thank You to psgpol For This Useful Post:
    alexm1 (13th June, 2019), Col19 (17th July, 2019), SDfgdhfj (18th June, 2019), seal777 (5th July, 2019)
  6. #8449
    May 2018
    Brazil
    Quote Originally Posted by engycz View Post
    "New" VCDS version 19.6.0.6 doesn't work with Loader V8. Last version known to work is 19.6.0.5
    http://ge.tt/3r4WRaw2
    These files are not available until tomorrow, because the owner has reached the daily traffic limit.
    Poor think
  7. #8450
    Feb 2019
    Hey guys.
    Does anybody know which values are these diodes?
  8. #8451
    atmpitbull's Avatar
    Sep 2018
    i install today 18.9.1 akp and loader v8.0 not work engine with skoda fabia 1.4tdi 2006y. 18.9.0 work
  9. #8452
    Jul 2017
    Default 19.6.0c NEC, ARM and ...
    A few words about the C-Test.exe. If the test message appears:
    This means that the device is marked as "clone". After deleting the mark:
  10. The Following User Says Thank You to BASi77 For This Useful Post:
    kaalis (14th June, 2019)
  11. #8453
    Apr 2018
    Loader 8.0 is working with DRV 18.9.1 from 21.05.2019.
  12. The Following User Says Thank You to rak183 For This Useful Post:
    miouser (15th June, 2019)
  13. #8454
    May 2019
    UK
    thanks :: http://ge.tt/3r4WRaw2 :
    That's weird -- I have just downloaded it...!?
  14. #8455
    May 2019
    Dear Everyone,
    After reading lots of pages, I´m still looking for only a tested procedure for flashing a VAGCOM 11.11 cable (FT232BL & ATMEGA162) . I attached you the pcb photos of my interface.
  15. #8456
    May 2019
    Enyone have problem with VCDS 18.9.0 APK or VCDS 18.9.1 ENG on new update 1903 windows 10 pro ? VCDS.exe and VCDSLoader.exe does not start !
  16. #8457
    Feb 2013
    Quote Originally Posted by muygolfo69 View Post
    Dear Everyone,
    Do you have USBASP programmer? If not, buy one (+soldering iron- fine tip) and then if you handle to solder 4 wires to Atmega162.....came again and ask for more details.
  17. The Following User Says Thank You to alexm1 For This Useful Post:
    muygolfo69 (15th June, 2019)
  18. #8458
    May 2019
    (Thanks for your fastest reply!)
    Following your well appreciate piece of advice, I´m purchasing this USBASP programmer:
    https://www.ebay.com/itm/USBASP-USBI...MAAOSwPHJdA9K~
    ¿Are you agree?
    Kind Regards!
  19. #8459
    Feb 2013
    Yes, good choice . Until you will have it, make some search about
    -usbasp - pinout.
    - Atmega162 Au pinout_ PIN 1 to 4
    Get some tiny wires so you can solder them on Atmega.
    And will talk more when you have all "that stuff" (harware and info) on the table.
  20. The Following User Says Thank You to alexm1 For This Useful Post:
  21. #8460
    Mar 2018
    Dear Everyone,
    there is no protection chip and a diode on the board .... perhaps the bootloader is unlocked already.
