Page 568 of 854 FirstFirst ... 68468518558563564565566567568569570571572573578618668 ... LastLast
Results 8,506 to 8,520 of 12803
  1. #8506
    Mar 2018
    Quote Originally Posted by adicristi View Post
    Should I try Kolimer patch and 18.9 version?
    Sent from my Mi A1 using Tapatalk
    At your discretion, if you want version 18.9 then flash it. Everything you need you can find by returning a few pages back.
  2. #8507
    May 2019
    Sorry, still no loader for 19.6 ?
  3. #8508
    Jul 2017
    Default v 19.6.0.7
    I would consider separately the problems of clones and originals.
    Auto-scanning with original software ( v19.6.0.7 ) and original cable:
    With clone:
    As a result:
    The same test with the original:
  4. #8509
    Jul 2017
    Quote Originally Posted by sarapova View Post
    ... can you please provide a link to 18.9.1 r1 version for testing.
    Check your inbox private message.
  5. The Following User Says Thank You to BASi77 For This Useful Post:
    sarapova (21st June, 2019)
  6. #8510
    Jun 2019
    I'd really appreciate if someone could link or upload all the "possibly working with loader v8" original versions of vcds (18.9.0, 18.9.1, 19.x.x, etc) because at this point I tested the latest one from website, and it was doing all kinds of wonky stuff.
    I also tried 19.6.0.5 and it detected the cable when it was not connected to the car but did not detect it when it was connected.
    I'm think I should try 18.9.0/18.9.1 now but couldn't find a section of older versions on website.
    NVM. I think I figured out that after the flash older versions won't recognize the cable anymore.
  7. #8511
    EU
    Grab while you can. English releases: 18.9 to 19.6
    https://www32.zippyshare.com/v/2B27U4fn/file.html
    RT remove old releases from their website because of clone users like you.
  8. The Following 2 Users Say Thank You to kaalis For This Useful Post:
    Bastard2 (22nd June, 2019), vortexo (22nd June, 2019)
  9. #8512
    Mar 2019
    Quote Originally Posted by Bastard2 View Post
    Correct me if I'm wrong, Loader8.0 will still work with 18.9 and 18.9.1
  10. #8513
    Mar 2018
    Does new Kolimer loader beat MY2019 date checking now?
  11. #8514
    Mar 2018
    Hello friends! As I wrote earlier, I needed good quality cables at a good price. https://www.digital-kaos.co.uk/forum...=1#post3597185
    And although the price of the obd2cartool store for our forum VIP LINK was not bad for our forum, I experienced problems in paying, there is also no photo of the motherboard https://www.obd2cartool.com/vip-link...86o4so84i9m7r7
    Therefore, I had to find an alternative to Ali. And I bought a few pieces for myself and my friends. In the lot there are schematically the best clones that I came across today! Moreover, version 1 and version 2. Also a very good price at the time of purchase for version 1 is US $ 19.19 - 2 $ coupon, totaling 17.19 usd. Version 2 will be released 20.39 usd: https://www.aliexpress.com/item/VAG-...6b43688ecvybxC
    Who experienced the same problems as I was, glad to help with the purchase! These clones are of good quality. I think many of the photos will agree with me. Photo of the 2 version can be obtained from the seller! Good luck and good to all
    HTB1AJn4dwaH3KVjSZFjq6AFWpXag.jpgHTB1TyP4dEKF3KVjSZFEq6xExFXaV.jpgHTB1lNY4dv5G3KVjSZPxq6zI3XXak.jpgHTB1rIIfdwKG3KVjSZFLq6yMvXXav.jpgHTB1atEodqWs3KVjSZFxq6yWUXXaD.jpg
  12. The Following 4 Users Say Thank You to AleksLux For This Useful Post:
    Amiga64 (12th July, 2019), bg17aw (22nd June, 2019), RiHard (24th June, 2019), Tib82 (22nd June, 2019)
  13. #8515
    Jun 2019
    Quote Originally Posted by kaalis View Post
    Quote Originally Posted by bg17aw View Post
    I was misled by the "Interface: Not Found!" messages during initial tests. Turns out it's an intermittent thing and does not depend on the versions I was testing, it was just a coincidence.
    On the other hand though, I deduced that cable is connecting intermittently and that's why the interface was not found sometimes and why when it is found, I get so many connection errors while trying to access various modules.
    Pointers would be nice at this point.
    Just fyi, I have 2015 A3 and 2012 Q5 at my disposal and same thing happens on both. Sometimes the connection errors are rare and sometimes I can't even connect to a single module, I don't see any pattern to explain it.
  14. The Following User Says Thank You to Bastard2 For This Useful Post:
    Col19 (25th June, 2019)
  15. #8516
    Jul 2017
    ... Sometimes the connection errors are rare and sometimes I can't even connect to a single module, I don't see any pattern to explain it.
    Sometimes this happens if the cable is marked "Clone" (random imitation of failures). See the post #8457.
  16. The Following 2 Users Say Thank You to BASi77 For This Useful Post:
    Bastard2 (22nd June, 2019), lemta (24th June, 2019)
  17. #8517
    Jun 2019
    Hungary, IOT, home automation
    Sorry my amateur question, I tried to collect all informations in this topic, but I can't see the light on the end of the tunnel. I have an 2019 Skoda Octavia, and i would like to buy a cheaper cable, and use it wit VCDS (as i hink as well, I need the newest VCDS).
    If someone can sum up, what can i do, and recommend a cable, I will be happy.
    Have a nice day!
  18. #8518
    Jun 2019
    Quote Originally Posted by BASi77 View Post
    Good suggestion. I downloaded the c-test.exe. Run it, but readings were weird and inconsistent, so I just flashed the cable again from kolimer's zip.
    Now everything is working nice and proper (as nice as it gets on MQB), running very first version of VCDS 19.
  19. #8519
    fantomel's Avatar
    Mar 2009
    Us
    A little history lesson maybe some of you need it
    EN - DE - FR - IT - ES - PT - PL - HU - RO - NL - RU - SWE - CZ
    If you like my post and it helped you please press THANKS.
  20. The Following 56 Users Say Thank You to fantomel For This Useful Post:
    A3Qtt (24th June, 2019), AlexKudry (21st July, 2019), Amiga64 (27th June, 2019), Andrey1842 (24th June, 2019), angelx431 (26th June, 2019), atmpitbull (24th June, 2019), Aucor (25th June, 2019), AYD (1st July, 2019), Bastard2 (25th June, 2019), baubau2006 (26th June, 2019), bg17aw (24th June, 2019), bmw318isblack (28th September, 2019), Col19 (25th June, 2019), elpaso544 (24th June, 2019), FoxMulder (24th June, 2019), gini80 (10th April, 2020), Greg J (24th June, 2019), Gyula84 (27th June, 2019), hjkmd (5th November, 2019), jakuza (24th June, 2019), jan4 (24th June, 2019), janusz21 (25th June, 2019), jaslen (24th June, 2019), JTengyel (24th June, 2019), kaalis (24th June, 2019), kurekpit (25th June, 2019), kventis (27th December, 2019), labtecnomocion (25th June, 2019), lemta (24th June, 2019), LostAngel (1st July, 2019), Mandyno (15th July, 2019), Mario6 (24th June, 2019), mrle9 (24th June, 2019), Msmax (6th August, 2019), muygolfo69 (28th June, 2019), networkers (25th June, 2019), njoythegame (24th June, 2019), obd2cartool (25th June, 2019), pablobrsp (26th June, 2019), Papiti56 (28th July, 2019), paro44 (25th June, 2019), psgpol (24th June, 2019), rak183 (24th June, 2019), rch11 (24th June, 2019), RiHard (24th June, 2019), safm (15th July, 2019), SDfgdhfj (24th June, 2019), seal777 (1st July, 2019), Snakepit (20th July, 2019), Tib82 (24th June, 2019), tobyb (25th June, 2019), Tor999 (11th June, 2022), turboleak (24th June, 2019), vkon01 (8th December, 2019), vm44 (16th August, 2019), vortexo (24th June, 2019)
  21. #8520
    Mar 2018
    Thanks Fantomel!
    I also have 19.6.0 HGJ Loader Faile 4 writes. This is normal?
