Page 570 of 854 FirstFirst ... 70470520560565566567568569570571572573574575580620670 ... LastLast
Results 8,536 to 8,550 of 12803
  1. #8536
    May 2019
    central europe
    Quote Originally Posted by hid3 View Post
    What exact bug are you referring to? Can you describe it in detail?
    Its the Mk60 ABS bleeding procedure. If you get air trapped inside the ABS block, its almost impossible to get it out, trust me.I used vacuum, pressure, ten liters of fluid, and the brake is still soft. The special SW procedure should actuate the valves, the ABS pump and give instructions, how to step on the brake and when bleed. But RT probably ~~~~ed this up. Everything was OK, until some sloppy mechanic replaced brake fluid and got air inside. I had to brake hard, ABS activated, bubble of air escaped and a mild crash followed... Two next mechanics were unable to solve this problem. Everything on the brakes is changed, tubes, hoses, master cylinder, calipers, no leak...but the pedal is soft as never been before the first fluid change. Should not do it.
    Maybe there is some special program for this...? PM if interested.
  2. #8537
    Mar 2018
    Hello!
    ABS block good? If the valves get stuck, the brake oil will not go in the right direction and you will do so. Suzuki had such problems. The old brake oil is what is aquatic.
  3. #8538
    Jul 2016
    Vilnius
    Quote Originally Posted by Mumxek View Post
    I have much experience with VAG ABS systems. Including ABS units replacement, Master Cylinders replacements and tons of air trapped into the system. Since this is not ABS thread, I will send you a PM on this.
    * MK100
  4. The Following 2 Users Say Thank You to hid3 For This Useful Post:
    LostAngel (1st July, 2019), Mumxek (29th June, 2019)
  5. #8539
    Nov 2012
    Ukraine
    The Current version is:
    Release 19.6.1
  6. #8540
    Not work with L8.0.
    On 32 bit Fail2, on 64bit memo err and "Hook error".
  7. #8541
    Jul 2016
    Vilnius
    19.6.1 is nothing more than their attempt to do quick and dirty fixes for the autoscan and other problems they introduced themselves
    * MK100
  8. The Following User Says Thank You to hid3 For This Useful Post:
    liviudiaconu (1st July, 2019)
  9. #8542
    Member seal777's Avatar
    Jun 2012
    Romania
    Quote Originally Posted by kaalis View Post
    Grab while you can. English releases: 18.9 to 19.6
    https://www32.zippyshare.com/v/2B27U4fn/file.html
    RT remove old releases from their website because of clone users like you.
    Please reupload the link ?
    Thanks and have a good day !
  10. #8543
    EU
  11. The Following User Says Thank You to kaalis For This Useful Post:
    seal777 (3rd July, 2019)
  12. #8544
    Jan 2019
    Hi,guys i have problem with my interface the programmer show me always error ID
    FF FF FF
  13. #8545
    EU
    This doesn't work that way. Describe your problem, post images of programmer, interface, how it's connected together, etc.
  14. #8546
    Dec 2011
    Hello everybody. I need your precious help.
    This is my situation: I have a fully registred and fully functionally (VCDS 10.6.4) HEX+CAN VAG11 cable (chinese? don't know!).
    It's equipped whit the ATMega162 (16AL) an FT232RL chip and a no tag GAL (20 pins).
    The VAGCOM_HWType result is this: HW_Type.jpg
    ...but when i try to flash EEPROM using VAGCOM_EEWriteLang, at the end of operation it says: Fail.jpg
    For helping you, I've seen than theere is no connections between ATMega162 pins 34/35 and GAL's pins 4/5 but anyway HWType read an 0x44 HW version.
    What can i do?
    Thanks in advance
  15. #8547
    Jan 2019
    When I try to program the interface the software show error ID FFFFFF
    I have tryed with usd asp and Tl866II plus,connected with SPI port
    0x46 Hw
  16. #8548
    fantomel's Avatar
    Mar 2009
    Us
    That interface is a BM/BL model, so you need to change pid in eeprom writer. If you can't write it like that then for sure your lockbit is not CC but C8 and then ... you need to do it by programmer.
    If you like my post and it helped you please press THANKS.
  17. The Following 4 Users Say Thank You to fantomel For This Useful Post:
    kaalis (3rd July, 2019), rch11 (3rd July, 2019), seal777 (5th July, 2019), zarbazan (3rd July, 2019)
  18. #8549
    May 2019
    someone who can help me with these codes of failure, my car is an ibiza 6j
    Address 08: Auto HVAC (J255) Labels: 6R0-907-044.clb
    Part No SW: 6J0 820 043 HW: 6J0 820 043
    Component: Climatronic H07 0304
    Revision: S0000000
    VCID: 61C89D187849AB4EE5-8034
    00898 - Control Circuit A/C compressor
    007 - Short to Ground - Intermittent
    010 - Open or Short to Plus - Intermittent
    00457 - Control Module for Network (J519)
    013 - Check DTC Memory - Intermittent
    Address 09: Cent. Elect. (J519) Labels:. 6R0-937-08x-09.clb
    Part No SW: 6R0 937 087 A HW: 6R0 937 087 A
    Component: PQ25 BCM H07 0012
    Revision: BE007001 Serial number: 9424B033090193
    Coding: 7D882B80887326000A300400740B1CC80040400F608C000020 00
    Shop #: WSC 64564 324 38760
    VCID: 3B740F70BA65A19E9F-806E
    Subsystem 1 - Part No SW: 6R0 959 801 A HW: 6R0 959 801 A Labels: 6R0-959-801.CLB
    Component: J386__TSG_FT 001 0238
    Serial number: --------------------
    Coding: 020000
    Subsystem 3 - Part No SW: 6R0 959 591 HW: 6R0 959 591
    Component: J245/J878 H04 0054
    Serial number: 849200043345
    Coding: 000003
    Subsystem 4 - Part No: 1K8 951 171 A
    Component: DWA-Sensor 001 0103
    Coding: 000000
    Subsystem 5 - Part No SW: 6R0 959 811 HW: 6R0 959 811
    Component: J388__TSG_HL 001 0245
    Coding: 000000
    Subsystem 6 - Part No SW: 6R0 959 812 HW: 6R0 959 812
    Component: J389__TSG_HR 001 0246
    Coding: 000000
    01700 - Alarm Horn for Anti-Theft System (H8)
    Freeze Frame:
    Fault Status: 01100111
    Fault Priority: 3
    Fault Frequency: 1
    Reset counter: 12
    Time Indication: 0
    01044 - Control Module Incorrectly Coded
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 2
    Fault Frequency: 3
    Reset counter: 255
    Mileage: 0 km
    Time Indication: 0
    Date: 2013.11.05
    Time: 00:00:01
  19. #8550
    Mar 2018
    error------------------
