Page 57 of 854 FirstFirst ... 747525354555657585960616267107157557 ... LastLast
Results 841 to 855 of 12803
  1. #841
    Zagreb
    Its the same version as Bosnian only sels like Croatian ... no I dont have it , just saying that there are other versions .
  2. #842
    Oct 2010
    Polska
    VAG 908.1 cloned cable with 232RL Chip need only new dump for use with polski or german 908 Software Version?
    Have someone good dump or solution for other language as english?
  3. #843
    Dec 2010
    Hi, I have a VAG106 with 232BL recovered with the 908 dump found here, I just bougth a VAG1062 with 232R but for some reason its not saving long coding. Is it posible to dump the VAG1062 eeprom to reprogram the VAG106?
  4. #844
    Quote Originally Posted by spongemak View Post
    with 1060 or 1062
    after you read DTC and go to live data screen
    do you see NA in some cells ?
  5. #845
    Newbie ciamardo's Avatar
    italy
    bug software this is was fixed on 10.6.3 release!!!
    Original Vag-Com HEX-USB+CAN Rev.B from Ross-Tech...
    ELM 327 chinese with 1.4b "genuine" soldering pic!!!
  6. #846
    Dec 2010
    Quote Originally Posted by tk500 View Post
    with 1060 or 1062
    No, everything seems to work fine, adaptation works, Long Coding doesn?t make any changes, this cable only came with 10.6.2 cracked software and doesn?t run on 10.6
  7. #847
    Dec 2010
    Quote Originally Posted by ciamardo View Post
    Do you mean 10.6.2 doesn?t work? is there a working software for this cable?
  8. #848
    Oct 2008
    On Earth
    The only sw you can use I suppose is the one you just have on your cd that it came with the interface.
    Good luck
  9. #849
    blackpirate's Avatar
    Jun 2009
    guys i saw that exists some patched softwares for 908 china clones all languages!
    anybody bought that?? it works?
    then dumps are not needed anymore!
    waiting for experts reply!
    10q
    If freedom is outlawed, only outlaws will have freedom!!!!
  10. #850
    DK Veteran KenshinPT's Avatar
    PT
    Quote Originally Posted by blackpirate View Post
    10q
    Some time ago someone tell us that story but no one could confirm.
    By the way... I bought a new USBasp from china and the dump inside ATMEGA8A is different from any other dumps available at fischl.de/usbasp
    If you are curious, just check this out:
    http://www.digital-kaos.co.uk/forums...p-dump-185493/
    Did it help? Push Thanks below
  11. #851
    Jun 2009
    Quote Originally Posted by KenshinPT View Post
    if someone will buy such a version and let us know if it works!
    and from 1 license it will be unlimited!
    cheers
  12. #852
    Jan 2011
    Hi, I've got the 10.6 cable from China, but after connected it for the first time to the computer straight away I've got message error code 1. Cable doesn't work on XP and Vista, totally crap from China. I looked inside cable and there is FT232BL which is good, and there is not STC chip, so should I only programm Atmega with 908 dump and that's it, or should I programm GAL as well?
  13. #853
    DK Veteran aminebot's Avatar
    Oct 2008
    Algiers
    10q
    the seller accept only western union!!!!!!!!!
  14. #854
    Jun 2009
    Quote Originally Posted by aminebot View Post
    yes!
    and hes not a trusted person from what i have read!
    it might be a cheater!
    maybe a rich person will take the risk and buy it!
    I'm ass broke!
  15. #855
    Oct 2008
    On Earth
    Quote Originally Posted by easyobd View Post
    What VID/PID it has?
    Good luck
