Page 582 of 854 FirstFirst ... 82482532572577578579580581582583584585586587592632682 ... LastLast
Results 8,716 to 8,730 of 12803
  1. #8716
    Jan 2017
    Ok, but you talk about v18.9, right?
    I want also solution how can I repair my v12.12. One of them is 100% works.
  2. #8717
    Nov 2017
    19.6.1 DRV is online
  3. The Following User Says Thank You to SDfgdhfj For This Useful Post:
    miouser (6th August, 2019)
  4. #8718
    Feb 2013
    Quote Originally Posted by performancepl View Post
    Why? Reading all data from first 12.12 can't working in another 12.12?
    In 99.99 % cases Atmega content is encrypted, so what you obtain reading with usbasp will not work to be flashed to another Atmega. You can try and you will see, after you manage to solve driver problem.
  5. #8719
    Oct 2017
    Germany
    Quote Originally Posted by SDfgdhfj View Post
    I guess ,it is not working with loader 9.2?!
  6. #8720
    Jul 2016
    Vilnius
    Quote Originally Posted by networkers View Post
    Beside of that, how could this Interface work without a 7805 voltage regulator?
    All the components are powered off the USB's +5V
    * MK100
  7. #8721
    Jan 2017
    Quote Originally Posted by alexm1 View Post
    @alexm1 but problem with driver problem i have with v18.9... this another case...
    now I want heal v12.12 for "training"
  8. #8722
    Oct 2017
    Germany
    Quote Originally Posted by hid3 View Post
    Yes sure, i realised that 10 Sec. after pressing the reply button
  9. #8723
    Jul 2016
    Vilnius
    Funny thing that if you put it first into USB then OBD2, it will not work. And if you unplug from OBD2 with intentions to plug into another car or so, you need to unplug from USB too because it also will not work. That cable is a really "wonderful" Chinese invention
    * MK100
  10. #8724
    EU
    You forgot about AIB, PCI and NEZ which were released today also.
  11. #8725
    Nov 2010
    After reading this very long thread I only can say: thank you guys...
    Not only for the persons answering many many times the same questions and posting solutions, but also for the ones looking for answers to their specific problems.
    I do learn from both...
  12. #8726
    Jan 2017
    I have a little progress in my cases (I programmed flash and eeprom on atmega162 by files from kolimer packs)
    Now in VCDS v12.12 i have info: not plugged into car - so this is positive message but on interface led wont light for any colors - red or green
    Did i broken some resistor or what? How can I test it?
  13. #8727
    Feb 2013
    The hardware is nr. 1 I think-low cost-LQ(?)
    Did you reflash with usbasp, yes?
    Pay attention to fuse/lock bits + do not mix flash from x44 with eeprom from x46(and viceversa).
    If you have use x46 dumps now try again with x44 dumps. (x44 and x46 are coresponding to hw type).
    And you said not working with 12.12 ...install new vers 18.9.0. or 19.6.0.
    Or save your time and buy something else.
  14. #8728
    Oct 2017
    I am used a good quality Chinese clone (am told), but it came with vcds loader v1.12, its been ok because i would update the software and all would be great but yesterday i mistakenly flashed it with vcds loader v9.0 ald flashed it with an option English only, now its invalid/unregistered, anyone help me on thw way to go?
    Am i was using 19.6.0
    Cheers
    Robin B
    Kess V2 . K-Tag
    MiniPro . UPA . VVDI2
  15. #8729
    I wrote you how to solve driver problem for "bad quality V2 clone" aka 18.9 clone. If not need, not ask.
    For transform your 18.9 into 12.12..only if you can extract content of 12.12 atmega. Atmega, as another coleague said, is encripted.
  16. The Following 2 Users Say Thank You to liviudiaconu For This Useful Post:
    fantomel (7th August, 2019), kaalis (8th August, 2019)
  17. #8730
    Nov 2015
    Does anybody know how to make a good clone cable work with my2019 cars?
    I know that everybody says it's not possible but I just saw a romanian guy resetting crash data from EPS ecu on Polo AW1 with VCDS clone
    I asked him but he didn't want to tell me anything
    Installing vcds 19.6.1 will solve this issue?
