use a mm to verify the 5 connections
New releases for DRV, PCI, AIB, signed august 15th.
Would any keen member be happy to flash my cable for a fee?
I dont have a programmer and my soldering skills are not great, especially on thin lines like these but I would need FW 1.96 flashed into my cable...
USBASP <---------> cable pin header (where 1 red line from usb)
GND<---------> 1 (black line USB GND)
NULL <---------> 2 (USB data line)
NULL <---------> 3 (USB data line)
5V<---------> 4 (red line USB 5V)
SCK <---------> 5 (ATMega 3)
MISO <---------> 6 (ATMega 2)
MOSI <---------> 7 (ATMega 1)
RESET <---------> 8 (ATMega 4)
USBASP_write_0x44.cmd
I bought a HEX-V2 cable from obd2cartool, but I can't get the disk working, none of the programs working or can be read, I have tried and contact them today, but havent get any answer and I would like to get started
anyone who knows where i can get the files
Usually takes ~12 H for them to respond, but allways sent me a reply. About your problem, will be more faster for you to find kolimer zip (read 10-25 pages back)and try to reflash by yourself or wait for them to answer and probablly they will give you a download link.
Dynamicdk (17th August, 2019)
Is there any hope to read UDS with this interfaces? Should I put it in the trash and buy OBDEleven or brand new VCDS?
First you post pics with your hw than you indicate conections Atmega to Usbasp prog. but you did not say if you have tried anything about reflashing your cable. Did you have/found kolimer.s zip? Did you tried to run "read" your Atmega by usb to see if your bootloader is on or of?
I reflashed my cable (0x44 newest flash - bootloader is enabled) but during scan got something like:
U1401 00 [008]
informations regarding extended error codes (UDS protocol) is available only when you use newest interfaces. (I translated it into english by myslef).
What vcds vers. you use and what is the car year?
19.6.1 and MY 2015 and 2017.
I had no such problems with 18.9.0 . Until now i see that newer vers. brings more problems than benefits. Try with 18.9.0 and see if works different.
Did you use it with UDS modern cars?
Can anyone send me the 9.2 loader please?
