Page 599 of 854 FirstFirst ... 99499549589594595596597598599600601602603604609649699 ... LastLast
Results 8,971 to 8,985 of 12803
  1. #8971
    Jul 2019
    yes u can run 19.6.1 with Kolimer V9.2 and re-flash. Your cable needs to be plugged in or connected do 12v just follow the pdf guide.
  2. #8972
    @ hirez: But..you have in fact hw44 cable.
  3. #8973
    May 2013
    @ hirez
    right HW type GAL-AT162 chacked? When GAL connected to the Atmega162, then you have a HW44 type cable.
  4. #8974
    Sep 2019
    OK, I thought so looking at the PCB, but was not sure. Is that good or bad? But the HWtype tool shows it as 0x46 so I just though that should be right.
    Either way the EEflash will auto detect and flash the correct firmware?
  5. #8975
    Apr 2018
    Quote Originally Posted by winamax69 View Post
    @ hirez
    Both type's ATmega162 microcontroller connected to the GAL chip, but the difference is the number of the connected pins. In the case of HW 0x44 type pin 34-35-36-37, while in the case of HW 0x46 type only pin 36-37 are connected to the GAL.
    Quote Originally Posted by hirez View Post
    No worries about it, just plug it into your car and into your laptop, ignition on (for 12V), and run the \/AG(0M_EEWr!teL@ng app and it will do the rest of the job
  6. #8976
    Sep 2019
    Quote Originally Posted by Tib82 View Post
    Thanks!
    I will check the pins. It never hunts to be thorough, and I would rather not break anything.
    so... autoflash, run loader9.2 on original fresh 19.6.1, play at will?
    Edit: just checked and like the PCB would indicate, the PA0, PA1,PA2,PA3 pins are indeed connected to my PALCE16V8. That is a 0x44 and a good thing?
    Also: Does it mean anything important that my PID reads FA20 and not FA24?
  7. #8977
    1. For correct functionality must write correct version of Fw and EEPROM.
    Must use USB ISP programmer.
    2. The response 0x44 or 0x46 is about Fw already wrote in AT162. Not hardware respond 0x44 or 0x46.
    So if you have in your Hw44 wrote Fw46 will see "0x46". Not OK.
    But, only for test your cable can use EEWriter.
  8. #8978
    Oct 2017
    Can't someone come up with a video of how to flash and share it to those who need it like me n hirez, the video should show how to use Kolimer's loader and other flashing tools like eewriter etc.
    I would help a lot.
    I had the same problem but I ended up using the same loader v1.12.
    However, Hires if u contact me, I will share with u what I did to solve mine bcoz I have a similar cable.
    I would prefer to use Kolimer's loader v9 due the it functionality, I looked at how it loads vcds and all I can say is its genius.
    Keep it up
    Cheers
    Robin B
    WhatsApp: +256752474714
    Skype: robin_bga83
    Kess V2 . K-Tag
    MiniPro . UPA . VVDI2
  9. #8979
    Jul 2019
    Is your bootloader unlocked ?
  10. The Following User Says Thank You to Lolo4321 For This Useful Post:
    robinbga (30th September, 2019)
  11. #8980
    Oct 2017
    Yes
    Kess V2 . K-Tag
  12. #8981
    Jul 2019
    Ok,
    First step:
    Plug in the HEX CAN cable into the laptop
    Install Ross Tech software downloaded from their site 19.6.1 (HEX CAN must be plugged in during installation)
    -( During install accept installation of drivers)
    Don't open VCDS after install.
    Go into you car and plug in the HEX CAN cable ( Ignition on)
    Open Kolimer v9.2 folder
    Run VAGCOM_HWType.exe - to confirm that your bootloader is unlocked
    After that run
    VAGCOM_EEWriteLang.exe
    (HEX CAN must be plugged into the car, or supplied 12 V on the bench setup)
    after that Open the directory in which u installed Ross Tech software
    Copy the loader from Kolimer V9.2 folder into the Ross tech directory
    VCDSLoader.exe - Right click on it and -> Send to desktop.
    Close all folder, and run VCDSLoader from desktop
    enjoy
  13. The Following 3 Users Say Thank You to Lolo4321 For This Useful Post:
    bmw318isblack (30th September, 2019), girolamodisidisi (4th October, 2019), manu5 (30th September, 2019)
  14. #8982
    Oct 2017
    I tried that at some point and its refused to be detected by 19.6.1.
    I did exactly that.
    When I opened eewritelang, I selected English I think 0x46 bcoz the original loader said that.
    It failed to work
    Kess V2 . K-Tag
  15. #8983
    Jul 2019
    Quote Originally Posted by robinbga View Post
    I did exactly that.
    It failed to work
    Kess V2 . K-Tag
    Uninstall all software and remove Hex Can from hardware...
    Than try again.
  16. #8984
    Oct 2017
    Quote Originally Posted by Lolo4321 View Post
    Than try again.
    I really don't know what u mean, remove hex can from hardware.
    Kess V2 . K-Tag
  17. #8985
    Sep 2019
    Quote Originally Posted by kolimer View Post
    Loader v9.2 released! It improves compatibility with non English versions and VCDS 19.6.0 version.
    http://ge.tt/6I9tkOx2
    https://www101.zippyshare.com/v/biPvu9Lt/file.html
    https://www.sendspace.com/file/5qr55f
    https://uptobox.com/l96rbs2lo9h6
    Kolimer ......
    Dear Kolimer
    The 19.6.2 Is out, Did you noticed? I´m eager to test the new version on my Car to see if im lucky
