Page 601 of 854 FirstFirst ... 101501551591596597598599600601602603604605606611651701 ... LastLast
Results 9,001 to 9,015 of 12803
  1. #9001
    Mar 2018
    Quote Originally Posted by rak183 View Post
    Wich hardware type is this interface.
    https://www.obd2cartool.com/atmega16...tdilehb116vdh7
    HW 0x44 .
  2. The Following 2 Users Say Thank You to Roma77 For This Useful Post:
    bmw318isblack (3rd October, 2019), rak183 (3rd October, 2019)
  3. #9002
    I just bought this USBISP burner, but which pins should I use to program my Hex-V2
  4. #9003
    Sep 2019
    @Dynamicdk: Did you check it first with HWType, maybe the bootloader is enabled?
  5. #9004
    Check the pins with multimeter or solder 4 wires directly on pins of Atmega.
  6. #9005
    Feb 2013
    Quote Originally Posted by Dynamicdk View Post
    Here you have -hex v2- pinout header.
    For usbasp use google
  7. The Following 5 Users Say Thank You to alexm1 For This Useful Post:
    bmw318isblack (4th October, 2019), dmerkovic (2nd September, 2023), Dynamicdk (4th October, 2019), julo45 (15th October, 2019), seal777 (20th August, 2020)
  8. #9006
    I have one dead vcds clone hex v2.after changed LM2940 and 2x9241A it came to life with k1 k2 ok, but CAN line is dead.
    LM2940 is very very hot after a few seconds.
    What's the problem? i don't want to change CAN controlers if LM2940 will be so hot again.
  9. #9007
    Jan 2016
    Latvia
    Does anyone have a JED file for the ATF HW 46?
  10. #9008
    Nov 2010
    Quote Originally Posted by flavyus1987 View Post
    Did you test it in a car with CAN bus system?
    If the interface is only connected to power (+12V and GND) then the CAN bus is always shown as faulty.
  11. #9009
    Yes, tested on car, passat b6.
    I had change MPC2515 too, same result.i don't have a TJA1050 and quatz.but i think, is to much to work.
    It is better to buy a new one.
  12. #9010
    Nov 2010
    Check what voltage levels you have on your CAN pins and chip power pins...
    you can always buy another one...
  13. The Following User Says Thank You to Msmax For This Useful Post:
    bmw318isblack (5th October, 2019)
  14. #9011
    Sep 2019
    The LM2940 is nothing else then the LM7805 (and they can get quite hot ).
    I would check the voltage around LM2940 (Vin and Vout) and the capacitors around it.
    If nothing fund then hook up an ammeter to power supply of the VCDS and
    take one chip after another down until you see an drop on the ammeter ==> thats the defect chip.
    If you cant find anything after an hour or so keep it as spare and order a new one.
    Can't loose nothing ^^.
  15. #9012
    10x all of you.
    I found, in my mistery box two echivalent for tja1050: vn7342 & mpc2551. I'll try with one of them, it is the last chance.
    However, original is Ata6551, only speed is different.
  16. #9013
    Changed Ata with mpc2551 and LM is cold, but CAN still not ready, hmmm....
  17. #9014
    Jul 2016
    Vilnius
    This CAN Not Ready issue is becoming a sickness... Could you please continue testing until you find a solution?
    Hot LM2940 usually means some component is draining lots of power = shorted. In your case it looks like it was either ATA or MPC2551.
    Can you check all the tracks on the PCB related to CAN so that the continuity exists on all of them and none of them is burnt or broken?
    * MK100
  18. #9015
    It is alive now, uhhh...
    Change ATA with NV7342, and finally works.
    To many components changed, and a lot of time...
    And LM have normal temperature.
