Thank you kssj0001 but im not familiar with odis and ill rather stick to vcds. Ive been looking for the 1:1 V2 clone still cant find it. Help pls
What is the exact reason you're looking for the 1:1 V2 clone?
Name at least a few of them and you will get the links.
Cause at this point, everything can be done using the classic one
* MK100;
Im after the hex v2 because the classic hex+can doesnt access certain modules on 2019 vag cars for coding. My last cable that i had for a few years was a 15.7 which is a little outdated so i thought ill get the most up to date version which is a 19.6.1 i believe? Im in the process of returning the 19.6 hex+can cable that i bought recently so i can get a hex v2 that works with all cars including the newest ones.
Is anybody met with this type of PCB? The owner got v1.12 L0AĐ€R for it and a complicated registration method.
Is it good, average, or bad version? Can it use K0L's stuff?
done a hwtest ??
Tib82 (3rd November, 2019)
Helow. I have this vcds it used to work with 908. Now a bought a car and it is not working with it. Please cand I update it?? I have this pictures whit it.Img 1 (7).jpgImg 1 (8).jpgImg 1 (9).jpg
What are you waiting for? Run infotool about cable and then choose solution from pdf.
Sent from my SM-J510FN using Tapatalk
andrei_hrz (3rd November, 2019)
This is the problem. Don`t find the infootool and the other sofware(.bin) to write with my usbtoavr on the AMTEL. I read about 100 pages and I didn`t find a post with them. Can you help me find te post? pls![]()
Do a search in posts (results shown as posts not threads/topics) from user Kolimer and you will find it sooner than Christmas.
I have tried to find out what tipe of cable I have but I have this error ?error.jpg
i got a chinesee vcds version 14,
on the CD there are many installer versions 11, 12, and 14.
but there is only dll file(crack ?) for version 11?
there is no dll or loader for installer 14.
where can i find loader or dll or something so it can work with version 14.
i already sent message to the chinese seller but who knows if i will get the answer from him and when
i tried kolimer 9.2 loader with this 14. installer that is on the cd but it does not work, says interface not found.
only combination that worked is russian installer 11 and checz dll file for 11
Can anybody assist with security key codes. I am trying to do a forced DPF regen on a 2008 A3 (8P). Is there a list of codes available anywhere?
Cheers
