Page 60 of 854 FirstFirst ... 1050555657585960616263646570110160560 ... LastLast
Results 886 to 900 of 12803
  1. #886
    Dec 2010
    Quote Originally Posted by croatiaobd View Post
    That is what i have done the first but with no success...Which VID and PID should i put....The ones that were before "erasing" 0403 and FA24???
    Maybe im doing something totally wrong...After VID and PID input .inf files are created. Then after plugging USB, wizard pops up..the i choose folder with .inf files??? What is wrong?
    Did it..Works....Thanks...BUT....
    Then using FTprog i have programmed it to a "previusly saved file" but after unplugging it and then plugging it again....again says usb serial converter....???What is wrong...Like the drivers are not saved?
  2. #887
    Oct 2008
    On Earth
    After you install the drivers for new VID/PID u must use VIDPIDFix and then u can use FTprog or old Mprog ( I use Mprog).
    If it's still changing the driver u must to reprogramm the Atmega.
    Good luck
  3. #888
    EU
    Quote Originally Posted by aminebot View Post
    No , it work only with VCDS lite 1.0 , and it does not work correctly with some computers.
    I have tested it with multiple computers. None worked as expected
    VCDS-lite 1.0 with your loader shows somehow different fault codes.
    All others programs shows identical codes:
    - vag-com 311, registered
    - vag-com 311, shareware
    - vag-com 409, registered
    - vag-com 409 shareware
    - vcds-lite 1.0 shareware
    - vcds-lite 1.1 shareware
    All software running on Windows 7 x64 with administrator user and obd 2 cable from ebay.
    If you need log files from these programs, I can post them too.
  4. #889
    Dec 2010
    Quote Originally Posted by mattydr67 View Post
    Good luck
    But then i get this....Is there still hope for me???
  5. #890
    Jan 2011
    I have a small problem with my cable. The line "Fully Registered / Activated" in the about screen sometimes disapears. And then VCDS thinks it's in shareware mode.
    It's a Vag-com 805.1 cable and works fine with version 805.4 on Windows XP. (strangly, this version was included on the cd rather than 805.1).
    Is this a known error?
  6. #891
    DK Veteran aminebot's Avatar
    Oct 2008
    Algiers
    Quote Originally Posted by kaalis View Post
    i know this problem , i can fix it only when i have a computer with this problem in my hand , i tested the loader on more than 10 computers , but i never got the random faults.
    skip this step and try mprog or Ftprog
  7. #892
    Dec 2010
    but then it seems that this "written" data does not work well because i dont get "ross tech diret interface"
  8. #893
    Oct 2008
    Algiers
    you used Mprog or Ftprog ?
    have you modified some keys in windows register (regedit) ?
  9. #894
    Dec 2010
    @aminebot
    I bought a 10.6.2 cable and the hardware is identical to the photos of your FT232R solution Tutorial, the problem I have is that everything seems to work fine but the cable doesn?t make changes in long coding, do you know if this is a hardware or software problem?
    If I use the 10.6.0 cracked software I get a time out message error.
  10. #895
    EU
    What if, cause of this problem is cable itself and not computer?
  11. #896
    Oct 2008
    Algiers
    Quote Originally Posted by spongemak View Post
    @aminebot
    you get an error message when you write coding ?
    are you sure that you are entering a correct coding for the control unit ?
    do you have this problem with short or long coding ?
    No , the problem is in the loader.
  12. #897
    Dec 2010
    Ft prog...no, nothing more than "programming" interface with renamed .ept file into .xml ....
  13. #898
    Dec 2010
    I dont get an error message, coding is correct, I get coding acepted but when I go back notice there is not change in the coding (I already tried with other modules, same problem) the problem is with long coding, haven't test short coding, adaptation works fine.
  14. #899
    Oct 2008
    Algiers
    set a random workshop number (differente from 00000) in the options window of VCDS , and try again.
  15. #900
    Dec 2010
    I know that im probably boring with this questions "why this and why that but....Why is this happening...Chip type FT245R?????(attached picture)
    Also i have noticed when opening .ept file for FT232RL ("VCDS 908 FT232RL.ept")in Mprog stands for Device Type: FT232BL ....not RL? is it mistake?
