Page 610 of 854 FirstFirst ... 110510560600605606607608609610611612613614615620660710 ... LastLast
Results 9,136 to 9,150 of 12803
  1. #9136
    Oct 2019
    Quote Originally Posted by alexm1 View Post
    See post #9137- download zip file.
    There you will find hwtype tool
    Connect your vcd$ to car + your laptop
    open/run hwtype and scan your tool- post here results- picture.
    The picture you posted above are not clear enought to see what is writen on the pcb parts, so , read / look for Atmel Atmega 162 Au, if you find it let us know.
    2B999F8C-4E10-4C92-96D0-845AB3969C1B.jpgCA5454A2-9002-4DE4-8A9E-FF6604BF8747.jpgAdsız.jpg
    I wrote the individual chips because the picture is not clearly read. it doesn't work when i connect it to the car like in the picture. com does not see 1-2-3-4 ports. vagcom 18.9 EN + DE HEX-V2 - 2018 release. I have to polish it again, but I don't know how. I need all the polishing files in usb and com port files
  2. #9137
    Mar 2017
    If bootloader is unlocked, download v9.2 from kolimer after that write with VAGCOM_EEWriteLang polish language, than you install vcds poland and update firmware.
  3. #9138
    Oct 2019
    Quote Originally Posted by Xaby View Post
    Can you send me the files ?
  4. #9139
    Apr 2018
    Quote Originally Posted by blackworms View Post
    https://www.digital-kaos.co.uk/forum...=1#post3714915
  5. #9140
    Oct 2019
    I'm trying a Vw polo 6n. vcds 18.9 + loader v7.0 was successfully written and vcds approved the license but did not work when I installed it in the car. Will the update be the solution? raise loader 9.2
  6. #9141
    Apr 2018
    Use loader 9.2. Y have to flash your cable. See read me file inside loader.
  7. #9142
    Oct 2019
    Quote Originally Posted by rak183 View Post
    From the loader file you mean boom
  8. #9143
    Top Poster jan4's Avatar
    May 2018
    somewhere in Belgium
    read your pm
  9. #9144
    Col19's Avatar
    Jan 2019
    France
    Hi friends,
    I see that the cable with STM32 is out but the manufacturer of this clone is as greedy as ro$$teak In short, i prefer to stay with my atmega162 enough for my stuff.
    Exactly i would like to ask a question to the experimented, which version is really functional with this He><V2 ? the 19.6 is not stable at home, the 18.9 is stable but as a lock, it is necessary to choose an even older version for the encodings... ?
    Thanks and respect to the forum and friends such as Kolimer and all the big the sharing.
  10. #9145
    May 2013
    Hello everybody,
    Is this cable upgradeable?77002183_544144789466172_648393100800032768_n.jpg72758198_2433009816810473_4069973136391536640_n.jpg
    Cable is blocked because of Internet connection.
    C-test shows: Atmega162 Read error.
    regards winamax69
  11. #9146
    Feb 2013
    Yes, Will do by usb using "things" from Kolim3r zip or by usbasp.
  12. #9147
    May 2013
    VAG-Com HWType:
    VID / PID : 0403 / FA24
    FT Serial : RT3S7QOI
    FT Description : Ross-Tech HEX-USB
    FT Chip ID : 0x503E8C25
    FW Version : 1.78
    HW Version : 0x44
    Identification : ROSSTECH
    SN : 0x00A8F2A9D716
    Language : Chinese - ZHS
    Bootloader : Enabled
    but
    I tried to write eeprom and I get this message: Writing firmware failed. Invalid bootloader?.
    I think I must flash Atmega with USBASP. Am I right?
    Cable has no GAL chip, but HWType shows: 0x44
    How can I identify 100% is a 0x44 hardware typ?
  13. #9148
    Jun 2012
    Hello, can anyone tell me which cable should I get? Is V1 with M162 good enough? Right now I have prehistoric v11.11. It works fine, but you know, maybe a little updated version would be better. If I understand correctly, V1 doesn't support whole MQB platform, so does it mean all cars listed under wikipedia.org/wiki/Volkswagen_Group_MQB_platform are no go with V1?
    Either way, is this version ok? https://imgur.com/9I7KOTH
    Thanks for any info...
  14. #9149
    Feb 2013
    Quote Originally Posted by winamax69 View Post
    VAG-Com HWType:
    FW Version : 1.78
    HW Version : 0x44
    SN : 0x00A8F2A9D716
    but
    Has no GAL but there is ATF(same thing).
    So, if reflash by usb failed, try with usbasp.
    Pay attention with fuse bits and choose 0x44 dump.
  15. The Following User Says Thank You to alexm1 For This Useful Post:
    winamax69 (13th November, 2019)
  16. #9150
    May 2013
    Thank you, I'll try it with usbasp.
    Updated:
    With Usbasp I flashed Atmega then With Mprog the FTDI chip. And with Hw write the eeprom with own language file. Now work like a charm with KLo@der 9.2.
    Thank you very much.
    Tapatalkkal küldve az én SM-G920F eszközömről
