For who is interested, i just received this cable https://www.aliexpress.com/item/4000...69184c4dCLpdvO
And it works perfectly, v1 with v2 case.
Yesterday I tried to do something in an 2019 Octavia (is is only 2 weeks old), My cable (0x46 with 1.9.6) could do the autoscan, but it couldn't download the 09 centr. elect. admap, and the adatptation button is grey in this module (I used the 31347). It means, the V2 cable is needed for this car, or a newer software will enough for the adaptations?
Someone tried the 0x46 cable with 2019 car? what sas the result?
which version of loader does it contain. Thank you
safm Hello friend , which versions of vcds does it contain and languages,
I got one from that seller as well, works perfectly, comes with a CD with the loader, but of course you can just use any loader you want.
The bootloader is unlocked, of course.
Hi is there anybody on this forum that can help with the download link or software for the version of Vag k+can Commander in the attached picture,
May i ask anyone to confirm that this cable is NOT working. I understand that it needs ATMEL chip, which is NO installed here.
This is not v€d$ cable, probablly is Vag K.
From Aliex.. if you are lucky, you get a working one. There is other seller (obd2cartool) from where I buy and had a good experience with it.
Did anyone try hex can v1 on mk7 golf, does it work?
Version 19.6.0 work ok with Kolimer patch.Version 19.6.1 and 19.6.2 not ok (ROD file problem).
Sorry for the n00b question, I just got a A4 B8 2008. What version of VCDS/VAG Com do I need for this car?
thanks aj
