Would you please post a snapshot of the "Device Manager" page of your VAG-COM device like this:
obd2cartool is just a re-seller like many other stores. Im not sure if they claim to be 1:1 v2 why didn't they came here to advertise it?
pocinas (30th November, 2019)
Anyone can help for me Loader 1.2 activation?
The seller does not respond![]()
Thanks 🙏
If y have atmega chip flash your interface with kolimer ...
Col19 (2nd December, 2019)
Hi, your loader too old, let your seller send the newer loader to you
I got problem because vcds work me with FRN and ADP (FRN - think French ADP is Polish), i prefer use ENG but doesnt with Eng vcds 19.6.2... tried 19.6.1 as well.. dont recognize interface.
His PC os may be the 64bits, when installing vcds choose option install 32bits to 64bits.
I got a cable from a guy who took down all USB cable wires from PCB (I don't know how). He or somebody else tried to find the right wire order but they made an ugly solderint surface. Luckily the PCB pads are silll good enough.
I searched the same PCB to check the wiring but with the same wire order even the Windows cannot recognise the USB device. No "ding-dong" sound on plug in the USB port. Is anybody knows what should be problem or the right USB wiring order?
no matter what form the pcb.
The operation of the interfaces is the same.
The connection of the USB is identical.
I did a quick search and I found 3 types. Basically the clones have the same wiring, but now I'm asking for the genuine.
Col19 (5th December, 2019)
Logic guidance:
1.See picture and you have a point where to start.
2. Start with BLACK wire-
Use a multimeter to check continuity from midlle leg of the LM7805 -voltage regulator- to one of 4 pads- solder Black wire there.
Black and Red should be left/rigth and Green and White in the midlle.
So, after you find the Black pad put Red on the oposite pad, " play " with Green and white.
Can vag-k+can cable be converted to vcds cable?
