VAG-COM/VCDS EVERYTHING - Page 617
Page 617 of 626 FirstFirst ... 117517567607612613614615616617618619620621622 ... LastLast
Results 9,241 to 9,255 of 9378
  1. #9241
    Nov 2019
    Downloads
    Uploads
    Is there any software package that came with the cable? You should try that driver first.
    Quote Originally Posted by morofsky View Post
    friend of mine left me a cable he said that his cable used to work but now the interface is not being found. the device driver gives code 10 and i cant find the device neither under MProg or VAGCOM_EEWriteLang, any advices what can i do to revive it? it is china replica with ftdi ft232rq and atmel mega 162
  2. #9242
    Jul 2019
    4
    Downloads
    Uploads
    hallo, can I have the Link from HEX V2? Thanks
  3. #9243
    Nov 2019
    9
    Downloads
    Uploads
    Maybe here
    https://www.obd2cartool.com/diy-vag-...hipping-p-1388
    i am waiting for an special offer to dk-member.
  4. The Following User Says Thank You to quadral For This Useful Post:
    Col19 (5th January, 2020)
  5. #9244
    Downloads
    7
    Uploads
    Already is blocked.
  6. #9245
    EU
    111
    Downloads
    Uploads
    19.6.2 ZHS and ZHT just released.
  7. #9246
    Jun 2019
    Hungary, IOT, home automation
    Downloads
    Uploads
    https://www.digital-kaos.co.uk/forum...=1#post3743045
    Before opening the hood, the adaptation button was grey in your vcds? We have a new Skoda Octavia, and the adaptation button is grey in the 09 cent. Elect, (after i wrote the security acces code)
  8. #9247
    Jul 2016
    Vilnius
    45
    Downloads
    Uploads
    Does anyone have the "HEX-V2" interface which is faulty due to "CAN not ready" issue? Please PM me.
    I can assist with repairing \/CDS interfaces.
    ABS module codings:
    * TRW systems in Passat B6/Tiguan;
    MK100 (experimental!);
    When requesting ABS coding, please supply all the information listed here.
  9. #9248
    Feb 2018
    Latvia
    Downloads
    4
    Uploads
    Hi. Can anyone share vcds 18.9 ENG?
  10. #9249
    Dec 2019
    9
    Downloads
    Uploads
    Quote Originally Posted by kashelis View Post
    You can try!
    Best regards VCDS.doc
  11. The Following User Says Thank You to Alesk For This Useful Post:
    Col19 (20th December, 2019)
  12. #9250
    Nov 2019
    Downloads
    Uploads
    No nothing was grey. Still I could adapt or code but the application will be refused at the final step.
    Besides, it seems that with 19.6 the adaptation of central elec was grey even after entering the correct access code . I'm not sure (poor memory) but that might be the reason why I always use 18.9.
    Quote Originally Posted by Zippair View Post
  13. #9251
    May 2019
    Downloads
    Uploads
    Hello! I have 19.6.2 if i want to connect to some modules, like 61.Batter regul., I've received "No response from controller" ...Is it the problem because is not a genuine version? Thank you
  14. #9252
    Nov 2019
    Downloads
    Uploads
    No. The reason is not whether the cable is "genuine" or not. It will always take some time for the software to be updated to support new modules of a new model car, so it's comon that some new modules are not supported by current software.
    At the same time, the manufacturer started intentionally limit the compatibility of old cables to promote HEX-V2, so sometimes, old versin software supports a module but new version does not.
    just try another version.
    Quote Originally Posted by bogdanbgd View Post
  15. #9253
    Mar 2019
    36
    Downloads
    Uploads
    I am trying to update a friend's old cable (11.11), please see pics:
    1) is this HW44 or HW46? I think it is HW46
    2) VAGCOM_HWType.exe says interface not found, every time, although the interface works on the car. Any idea why?
    3) Device Manager says "Rosstech Direct Interface" and VID:0403 and PID:FA30 but some tutorials say I should change FA to 20, how do I do that? They mention a software called "vidpidfix.exe", where can I find this?
    4) JP1 is briged (a connection exists soldered on the board), should I desolder it?
    5) The board already has the holes for programming interface, so am using those, is it alright if I connect the cable to a 12V supply and only use 4 wires from USBASP programmer to the board? So no VCC and no GND?
    6) No ATF/GAL?
    7) No L7805??
  16. #9254
    84
    Downloads
    34
    Uploads
    Your cable is a petard without GAL/ATF, without 7805.
    For work FA24, K0l1m3r solution. Or, external programmer with "46" settings. Until you don't rewrite FA24 is possible K0l1m3r solution not work.
  17. The Following User Says Thank You to liviudiaconu For This Useful Post:
    bg17aw (23rd December, 2019)
  18. #9255
    Mar 2017
    20
    Downloads
    Uploads
    Quote Originally Posted by bg17aw View Post
    6) No ATF/GAL?
    7) No L7805??
    Don't bother with that cable. Like liviudiaconu said, that cable is a piece of junk, without gal/atf or 7805 stabilizer. Don't waste your time with it, tell your friend to buy another one.
  19. The Following 2 Users Say Thank You to Xaby For This Useful Post:
    bg17aw (23rd December, 2019),rewease (28th December, 2019)
