ept file format is different from xml file format , i think that you can not only change extension from ept to xml.
See attached video , it show how to use Ftprog
i want to upload FT232R dump in xml format but i don't know if uploading dumps is against DK rules or not.
video3.rar
i want to upload FT232R dump in xml format but i don't if uploading dumps is against DK rules or not.
I know that a lot of peaple share this kind of dumps here even for Atmega.
So I belive it is not against the rule but for sure let a Moderator to replay and explain if this is against the rules or not.
I don't want you to be banned ( I said "I" but I suppose that is "WE")
Good luck
this eeprogrammer_rtqx.. is writting data (really), because is main purpose is reprogramm damaged cable, they also show what is before in memory, but after that, data is written there automatically. What is currious, that cable isn't recognized after that..
anyway, sorry if isn't clear the program is reprogramming tool and not reading tool
I have used my 805.1 cable with newer versions of VCDS, just to see if it worked or not. Is my cable now doomed?
Before I found this forum I was totally unaware that my cable could get damaged by VCDS. So I also didn't include ross-tech in my hostfile. Speaking of which, is it also possible to use windows firewall to prevent VCDS connecting to the internet?
BTW, how exactly is the cable damaged? Is it the contents of the 93Cxx chip that get overwritten or also the eeprom area within the atmega chip? As far as i understand at this moment, reviving the serial eeprom seems a lot easier than updating the atmega.
So guys....i'm going slightly mad...
Now my device is recognized as you can see in the attached pictures...as unknown device...no VID and PID...so how im going to make it work now-UDfixer can help me now!!? or?? I really dont know how i did it?
And while i was trying to use FTPROG as in video tutorial i got message : something like incompatibile devices or files (it is, i suppose, caused by not recognizing interface (friends one) as FT232...it was recognized as FT245-as posted few posts before...and mine is still recognized and can be programmed by FTProg-but does not work with software-after plugging it into OBD says "no interface found")
And yes...friend is also mad...but not slightly..... And i'm trying to find a way to spend money in a better way....than buying new interface for him...:=)
It's wrong , please don't post unverified informations .
All serial numbers are valid if you know how to calculate encrypted data and checksums.
You get "failed self test" error when first checksum (2 bytes at adress @0011) is incorrect.
You can use firewall to prevent communication between VCDS soft and rosstech server.
In most cases using lower version does not damage interface.
First data damaged is eeprom area in atmega , the last damaging step is the FTDI eeprom ( 93CXX for FT232B or inside FT232R).
I uploaded a loader for 812 version in a previous post, this loader can repair modified data into Atmega.
For more info , see this post
Yesterday I was replacing my old AT93C56A (ATMEL EEPROM) 8/16bit without Program Enable to another one from Microchip: 93LC86C 8/16bit with Program Enable.
Datasheet is clear: when PE is tied to GND, program is disable, when is tied to VCC program is enable and this pin cannot be left unconnected.
My PCB has this pad connectd to GND so I lifted up that pin and tied to VCC. Till now everything OK, right?
I tried to program the EEPROM via FTPROG and MPROG and no matter what I couldn't.
That's when I remembered that FT232BL only supports 93C46, 93C56 and 93C66... But I tought that the FTDI's datasheet was old and newer versions of the 93C will also be compatible.
I tried with another one: ST M93C86 and the result was the same.
I emailed FTDI if to check If I am doing anything wrong of if FT232BL doesn't support this EEPROM's
