Page 620 of 854 FirstFirst ... 120520570610615616617618619620621622623624625630670720 ... LastLast
Results 9,286 to 9,300 of 12803
  1. #9286
    Jan 2020
    Hello Woodward395,
    I hava follow the instructions.
  2. #9287
    Jan 2020
    Hello Woodward395,
    I have follow the instructions.
    Someone on this forum olso told me to disconnect the pin 9 to the R50 of the chip.
    This olso not working.
    I have read the eprom, see picture but when i want to write it says Not in Bootloader mode.
    http://prnt.sc/qjyjvp
    http://prnt.sc/qjyk6a
    http://prnt.sc/qjykc1
    Quote Originally Posted by WOODWARD395 View Post
    download and follow these instructions you have correct chip to update firmware you need it plugged into vehicle or 12v supply to cable.
    thanks to kolimer
    https://www.sendspace.com/file/5qr55f
  3. #9288
    EU
    Quote Originally Posted by cebbes30 View Post
    Try following them again.
    2 hours later...
    So, have you connected pcb to programmer already? Which pins are unclear?
  4. #9289
    Jan 2020
    I didn`t do this.
    i thought disconnecting pin 9 could flash.
    USBASP hw version 0x46 can you explain because the instruction shows HW type 044
    Quote Originally Posted by kaalis View Post
    2 hours later...
    [COLOR=rgba(0, 0, 0, 0.87)]I didn't do this[/COLOR]
  5. #9290
    EU
    Then you have found loader version below 8.0
    See post #8693 and download latest. If links are dead, read along couple pages further.
  6. #9291
    Jul 2016
    Vilnius
    Read the Readme.pdf file from the very beginning to the end. Read every sentence. Understand what it says. The material covers everything you need to know and need to do.
    * MK100
  7. #9292
    Jan 2020
    Hello All,
    I have read everthing i have olso the latest boatloder, so i have even tried at the first time with this. i have read hw type so ther for the pictures.
    So the only option to let this work is soldering the usbap conections to the Atmega and MCP.
    So whe the boatloder like my cable is locked you nee to soldering.
    I read olso Programming:
    avrdude.exe -p m162 -c usbasp -e -U lock:w:0x3f:m -U efuse:w:0xf9:m -U hfuse:w:0xda:m -U lfuse:w:0xcd:m -U flash:w:Flash1.96_HW_0x46.bin:r -U eeprom:w:eepromavr.bin:r
    The programmer are not come together with the loader 9,2.
    where do i find this, and is the a instruction how to programm
  8. #9293
    EU
    Ok, let's make this topic even longer with this unique problem.
    You can download avrdude by googling for "avrdude". Put avrdude.exe and avrdude.conf into unzipped loader archive and run that command with connected programmer. There's even a batch files for 0x44 and 0x46 it (usbasp_write_0x44.cmd and ...0x46.cmd)
    After successfull finish you can use vagcom_eewritelang.exe without programmer and choose whatever language you want because modifying avrdude parameters and extracting eeprom content of other languages could be too complicated for some...
  9. #9294
    Jan 2020
    Can anyone confirm that clone vcds cable 19.6 can read the Address 4B: Multifunc. Module
  10. #9295
    Top Poster jan4's Avatar
    May 2018
    somewhere in Belgium
    NO ;
    44-Steering Assist -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    4B-Multifunc. Module -- Status: INTERFACE NOT COMPATIBLE
    52-Door Elect, Pass. -- Status: OK 0000
    5F-Information Electr. -- Status: OK 0000
  11. The Following User Says Thank You to jan4 For This Useful Post:
    godsmack87 (8th January, 2020)
  12. #9296
    Oct 2019
    Hello guys (and girls, if any),
    I have a VCDS cable from china since 2018. I have been using it without any issues. 3 or 4 moths ago, with help from this forum I updated the cable to version 19.6.2 with Kolimer loader. Everything went perfect.
    Since the last update, I retrofitted the RLS on my 2013 Jetta, did some scans, played with the light settings on BCM - everything perfect.
    Now I try to retrofit CCS and I get stuck on the 01 Engine Module - I receive "Request out of range" error when trying to activate the CCS (long-coding).
    On the same module I tried to deactivate "Extended Service Interval" and got the same error. I even tried to press Do IT button with the original coding and I am getting error.
    It seems that long-coding is not working at all on my module.
    This is my Engine module:
    Address 01: Engine (J623-CBZB) Labels:. 03F-906-070-CBZ.clb
    Part No SW: 03F 906 070 JF HW: 03F 907 309 R
    Component: SIMOS10.12AH10 3608
    Revision: --H10--- Serial number: 00000000000000
    Coding: 001900D6230400080000
    Shop #: WSC 00066 123 00189
    ASAM Dataset: EV_ECM12TFS02103F906070JF 004004
    ROD: EV_ECM12TFS021.rod
    VCID: 6FED66BBB69D05374E-803A
    No fault code found.
    Readiness: 0000 0000
    Do any of you have any idea how to handle this? Maybe a Security Code is needed (I was not able to find one).
    Any hint or advice will be highly appreciated.
    Thank you all
  13. #9297
    Oct 2018
    Anyone know where i can download the VCDS 19.6.1 or 19.6.2 German version?
    Thanks!
  14. #9298
    May 2018
  15. The Following 2 Users Say Thank You to jan4 For This Useful Post:
    godsmack87 (8th January, 2020), PhilipArt (8th January, 2020)
  16. #9299
    Oct 2018
    Thanks jan4!!!
    I've used the forum search but there was no related results and i couldn't find the Fantomel's link (in Yandex) where he was sharing all available versions...
  17. #9300
    Dec 2018
    Okay basically Ill just sum up my research / how to:
    #1 Order tool from reputable supplier https://www.digital-kaos.co.uk/forum...74#post3575874
    option 2 without usb thingy. I ordered with the usb module due to not knowing any better. You dont really need it, unless you have an older/other cable you want to mess with
    Delivery took 12 days to UK, not working days. Ordered 27/12, dispatch and tracking 31/12, received 08/01, so quite quick during this busy? period.
    #2 while you wait for your delivery find loader https://www.digital-kaos.co.uk/forum...=1#post3639906 link 3 works 08/01/20
    #3 download and install vcds from official website or find a version you want
    #4 Once you have the tool heres a video of installation https://www.digital-kaos.co.uk/forum...=1#post3574522
    All the files are located in the loader you downloaded in #2
    You can skip video to 2;26 and just do VAGCOM_HWType check and if results match continue with VAGCOM_EEwrite.. flash. Once thats done copy loader into vcds, start VCDS with the loader you just copied and then just test the cable you bought. All was good to go in my case. Researching this took way longer than the actual install.
    Hope this helped some, I sure could used this when I was going through it
  18. The Following 5 Users Say Thank You to kventis For This Useful Post:
    cristianwushu (11th January, 2020), DiYei (19th April, 2020), jan4 (8th January, 2020), Mario6 (8th January, 2020), ronaldosaimi (20th April, 2020)
