VAG-COM/VCDS EVERYTHING - Page 621
Page 621 of 626 FirstFirst ... 121521571611616617618619620621622623624625626 LastLast
Results 9,301 to 9,315 of 9378
  1. #9301
    Apr 2019
    Downloads
    Uploads
    Quote Originally Posted by cebbes30 View Post
    Can anyone confirm that clone vcds cable 19.6 can read the Address 4B: Multifunc. Module
    Nope, I can't access that module on my MY19 Octavia. Everything else works perfect.
  2. #9302
    Aug 2018
    Downloads
    Uploads
    Can I update my cable? And Use 19.6.1?
  3. #9303
    Feb 2013
    73
    Downloads
    5
    Uploads
    Nope....not Atmega on your cable, in order to try an update you need a cable with Atmega. If your cable is stil "alive", used as it is, if not buy a new one and this time buy one with Atmega162 AU.
  4. #9304
    Aug 2019
    Downloads
    Uploads
    Quote Originally Posted by serdarurer View Post
    It looks like an ARM based cable. When I had one cable like that, I had tested it with original/not cracked vcds 19.6.1 and it "worked" (it was recognized as legit cable in about/settings section of vcds). I always run vcds with no internet connection on my computer, but I don't know if it makes any difference.
    You can test it and see if it applies to your cable. You don't need to change something or install another software, just the vcds version you want to test.
  5. #9305
    DK Veteran WOODWARD395's Avatar
    Manchester UK
    417
    Downloads
    52
    Uploads
    Question Desperate VCDs no longer working.
    hi again had my cable working great thganks to you guys on here and kolimer who done the crack for the software it has the progamable chip which i updated and as already stated worked great with most recent software.
    however tonight went to use vcds and says my licence is revoked just below cable number.
    anyone know anyway to fix this desperate as have my car in bits so now when I put it back together its going to be full of codes.
    can the cable number be changed in anyway. thanks.
    UPDATE have 9.6.2 working again, needed to re flash cable and its working again very happy guy.
    thanks for your help jan4.
    Education is not the learning of facts, But the training of the mind to think
    So hit the thanks button if I have enlightened you.
  6. #9306
    Manchester UK
    417
    Downloads
    52
    Uploads
    cebbes30 you have a programable chip if I remember correctly ATmega162 you should not need to unsolder anything download vcds and copy and paste vcds loader.exe to ross t--ch folder then create a shortcut to it.
    then use software as instructions to update firmware needs to be conected to 12volt supply or to the vehicle.
  7. #9307
    May 2011
    Downloads
    Uploads
    Hello dear friends,
    Needed a help, Does anyone know which Local Service is used by VCDS 19.6.2 (in PTT but I believe to be the same in other languages .. I think the service will be the same) in Windows?
    You can access these services via:
    Pressing the Windows-r keys after typing services.msc and enter on the keyboard.
    I ask this because I can not open my VCDS in PTT ... it opens the first information saying Kolimer X86 V9.2 ... But then does not open ... and nothing else happens ... once I had a similar problem in other software and I had to go to the service and put in automatic with start delay ... so I am asking myself to check if it can be the same problem ...
    I also noticed that the message Kolimer X86 is 32bits ... but my windows runs at 64bits ... But I do not know why it was installed to X86 I can not understand what happened here ...
    I would appreciate some help ...
  8. #9308
    Manchester UK
    417
    Downloads
    52
    Uploads
    Have you downloaded 19.6.2 from ross tech then closed it copied vcdloader to vcds directory then double clicked it to open it will then change vcd.exe to vcd.exel then all you need to do is right click on vsdloader.exe to highlight it then in menu click on send to, to create short cut to desktop.
  9. #9309
    May 2011
    Downloads
    Uploads
    Quote Originally Posted by WOODWARD395 View Post
    Already done that my friend... but i re-done like you say... Problem its same... Show Kolimer mensage in blue say OK... And dont open...
  10. #9310
    Manchester UK
    417
    Downloads
    52
    Uploads
    what do you mean wont open in ptt which OS you using have you gone into properties and tried operating in another OS system.
  11. #9311
    Apr 2019
    Downloads
    Uploads
    Hello everyone
    I have a problem with my Polish version VCDS AKP 18.9.0
    displays a message vcds can not ready
    What I did
    Reinstall VCDS
    I changed loader 7.2 to 9.2
    flash interface using VAGCOM EEWriteLang - successful
    Nothing helped. What else can I do
    Please help
  12. #9312
    Feb 2013
    73
    Downloads
    5
    Uploads
    What you can do?
    You should post some pics with PCB and tell us on what car (model/year) did you tried to use your cable?
  13. #9313
    Sep 2015
    Downloads
    53
    Uploads
    Uninstall the previous version and upload the new one.
    sorry to answer from @ vextre
  14. #9314
    Apr 2019
    Downloads
    Uploads
    I connected the cable to Scoda Rapid 1.6 diesel 2016 Year and Volkswagen Jetta 2015 Year
  15. #9315
    Jan 2017
    HongKong
    3
    Downloads
    Uploads
    obd2cartool online shop long holiday from 19th Jan. 2020--31th Jan.2020, the last shipping day 18th Jan. after sell service pls contact online skype, thnkz
