Have you tried installing newer/newest vcds version instead of doing that ^^?
Do you have a clone that is detected by vcds and feeding you wrong not existing rod filenames with swapped symbols?
Do you need to enter an access code on passat b6 CBA to code injectors? In the program in coding 10, there is no injector in the drop-down list for some reason, how to add them there?
@kaalis I installed newer and older versions. I changed the language to English by EEWriter Lang and installed the english version. When I do the test Can not redy
Where are the pics of your cable's PCB?
* MK100;
Have you read the _README.pdf file in kolimer's package?
* MK100;
I read so.
Can anyone tell me will VCDS Loader 9.2 is gonna work with VCDS 18.9.2? or should i google for 18.9.1?
can this chipset be upgraded i am using 18.2 need 19.6 ?? it uses kolimer patch to work
if not is this a good cable to buy
https://www.aliexpress.com/item/4000122237317.html
What you have can't update.
thanks to all the ones that posted, finally managed to update
i have a chinase cable and not working came with VCD 11.11,3photo_2020-02-01_14-45-38.jpg .. please any help to work again
