Page 624 of 854 FirstFirst ... 124524574614619620621622623624625626627628629634674724 ... LastLast
Results 9,346 to 9,360 of 12803
  1. #9346
    Sep 2016
    Can any one Recommend another place other than china to buy the cheap vcds with the atmega162 of course because there's a risk in buying from china now
  2. #9347
    Feb 2020
    Can anyone help me with my cheap ebay cable (https://www.ebay.com/itm/VAG-K-CAN-C...b9c8%7Ciid%3A1) I'm trying to read codes in vcds lite 1.2 and it keeps telling me no response from module.
  3. #9348
    Dec 2014
    PL
    mcskittle
    The vag k can commander 1.4 / 2.5 interface does not work with vcds lite 1.2. You must use the VAG KKL interface. Buy better vcds hex-can.
  4. #9349
    Sep 2016
    where to buy it cheap like china but ? i cant deal with aliexpress or any china u know the circumstance and the virus staff
    on Epay it is too expensive so where to buy it cheap again ?
  5. #9350
    Nov 2016
    Is there any "good" VCDS clone, I haven't been able to find any promising clone on the internet. We have one guy locally in bosnia who is claiming he has a HEX-CAN clone that runs without the loader, directly with the original program, and also is updateable. The price is ~150€. I am not too sure in this guy so I wanted to ask is this possible, and is there any other reliable source on the internet for a good VCDS clone, I am not looking for a 10$ unit but I am willing to pay anything for a working unit. How is it possible to have such good clones of tools like Kess V2, with purple PCB's that work almost 100% like original, but we don't seem to have any good VCDS?
    BTW I am co-owner of a original HEX-NET unit acquired from Ross-tech, but I want another clone unit that I can have for myself all the time.
  6. #9351
    Nov 2015
    I'm in the process of updating and old 11.8 cable.
    I'm having an annoying problem with usbasp programmer. When I connect either the vcc or the ground, in the pic it's disconnected, the programmer turns itself off and windows says that a device connected to the usb port is drawing too much current. If I move the jumper on usbasp from 5v to 3.3v position it doesn't happen.
    Did anybody have a similar issue?
  7. #9352
    May 2013
    @ilDandi
    May be you coonnect the wires inversely to the MCP2515 chip(I can NOT see the first pin of your MCP2515 chip beacasue of picture quality) and your laptop switch off the connection because of short circuit . You must connect the cables as described on this russian page:
    https://www.drive2.ru/l/517610218134177046/
    Connect the ground cable from USBASP to the USB BLACK WIRE of VCDS interface directly.
    You've better use multimeter in diode/beep mode to make sure the wires connected properly AND THEY HAVE NO SHORT FROM EACH OTHER! YOU MUST USE YOUR USBASP PROGRAMMER JUMPER 1 SWITCH IN 5V PROGRAMMER MODE!!!
    Other hepful webpage (here comes out the connetion from printed circuit board directly that means, here is the connetor of usbasp a female connector, so it is reverse!!!!)
    https://www.drive2.ru/l/480734522283917454/
    AND IT IS RECOMMENDED USE EXTERNAL POWER SUPLY WITH 12V CONNECTED TO YOUR VCDS CABLE FOR SURE as on the russian page described.
    The ODB2 pinouts( view: frontwise)
    I use allways external powersupply with 12V (I use a power supply from my satellite receiver)and check the wires connected properly and had NO PROBLEM so far. I've updated many cables succesfully without any problems.
  8. The Following User Says Thank You to winamax69 For This Useful Post:
    Achtuhr (14th February, 2020)
  9. #9353
    Feb 2020
    Can anyone tell me if this cable will work on my 2001 audi tt an does it come with software?
    https://www.obd2cartool.com/atmega-v...k7sd76ote72u43
  10. #9354
    May 2013
    @mcskittle
    YES and YES
    Gesendet von meinem SM-G920F mit Tapatalk
  11. #9355
    Jul 2018
    New version realeased:
    The Current version is:
    Release 19.6.2
    Data Version 20200210 / DS308.0
  12. The Following 2 Users Say Thank You to subzverb For This Useful Post:
    Achtuhr (14th February, 2020), kaalis (14th February, 2020)
  13. #9356
    In fact signed on 11.02.2020
  14. #9357
    Top Poster nicolas2015's Avatar
    Feb 2015
    somewhere in cornwall
    Good evening , any colleague around Plymouth or Cornwall in UK with a genuine VCDS cable? I need some help to do adaptation on audi A 4 B6 2003 1.9 TDI, i just need to adjust the volume of rear parking aid sensors , and my tool is not connecting to the 76- parking aid module. Obviously i'm happy to travel and to pay for the service. Many thanks!
    Vag-com, Op-com, Focom, Autocom,Multidiag, Forscan, Lexia....
  15. #9358
    Feb 2015
    It's weird because the tool is connecting to other modules that need 2nd k wire, but not to 76- parking aid. Just to mention rear parking sensors are working perfectly, i just need to adjust the volume as it's too loud. Pictures attached, also any ideas of upgrading this tool ? It's 11.11.3, i had it since 2013 and it's working Okay, i've been doing adaptations, coding, code reading and errasing fault codes. many thanks. Or any idea where to buy a good reliable newer version?
  16. #9359
    Jul 2016
    Vilnius
    This is a chinese mutant cable without GAL. Get a proper cable and everything will be fine.
    Oh, and this yours cable is only good for spares.
    * MK100
  17. #9360
    Feb 2020
    Does anyone know if obd2cartool.com works weekends cause I ordered my cable and paid for expedited shipping on the 13th and it still has not shipped?
