hello
i try to matching the key for polo 2003 using vag908
i use correct procedurefrom Ross-tech
still have a code 01179 and 01176
any one can help
thanks in advace
hello
any one can help
thanks in advace
I don't know if you remember, but I think that 93C86 cannot works, because amount of proper clocks is missing.. so means, that 93C96 needs more clock for reading/writing than 93C46/C56... I finally use 93S46 or something like it.. I wrote couple days before, that is working well with this memory
Yah I read that... but I just can find EEPROMs with Program Enable above 93C76 inclusive.
So I give it a try and ordered a couple 93C86 (16bit)
I can't find a 93C46, 93C56 or 93C66 with PE.
Give me the exact reference of that EEPROM so I can check if it has PE or not because the one you said above "93S46 is a "HIGHSPEED6-BITIDENTITYCOMPARATOR" =)
Thanks. This explains a lot.
Another question: I noticed that there are cracked versions of VCDS around. In what way do these differ from regular versions? Is it the damaging of the cable, or the internet connection, or something else?
Because if I understand correctly, an uncracked VCDS should work with a 3rd party cable as well, right?
Yes i am sure.
i know that all chinese dumps have first checksum equal to 00 00 , but it does not mean that this value is always 00 00 , try to change this value in any dump , and you will get Self test error
i didn't underestimate anyone , i just said that he posted wrong informations.
I don't know the difference because i never used chinese cracked versions , a cracked version can be better than original when it is cracked correctly.
VCDS original or cracked does not work with third party interfaces , except VCDS lite.
i think that the problem is caused by software incorrectly cracked , Try with another interface that work with original soft to be sure.
I do have another 106 cable recovered with the 908 dump and original software posted here and it works perfect, but I need new software with new labels.
I can't try this cable with other software since it only works with the 10.6.2 that came with it.try with 908
Chinese versions 10.6x do not work
Why 10.6 dump can't be share? why isn't free and so secret to get it?
It's not any secret
Not everything is for free in this life, that's why this dump ain't for free ( for now )
If you want it for free you have to wait till another upgraded VCDS dump will show up on black market and for sure this one ( 10.6.0) will be for free.
Then you'll can enjoy. For now you can find for free a previos versions 908 dump ( here in this great forum DK)
Use it and enjoy.
Good luck
