Page 633 of 854 FirstFirst ... 133533583623628629630631632633634635636637638643683733 ... LastLast
Results 9,481 to 9,495 of 12803
  1. #9481
    Mar 2019
    Quote Originally Posted by Roma77 View Post
    The problems that were fixed in version 20.4.1 can be read here
    https://forums.ross-tech.com/showthr...control-module
    The problems that are fixed in version 20.4.1 can be read hereThe problems that are fixed in version 20.4.1 can be read here
    Since we can only use these cables on older cars (before MQB platform), do we actually need latest version?
    Why not stick with 18.9 or whatever version works 100% ?
  2. #9482
    Mar 2011
    Default Software from cable copying
    I have a cable from Sklad 66.com. It is updated automatically. How can I download the original software from the cable? I need the software to repair another cable purchased from the same provider. Thanks.
  3. #9483
    Contact Sklad and ask him.
  4. #9484
    Jul 2016
    HI all - please treat a novice gently :-)
    I bought a VCDS cable and software (19.6.0) but cant get it to work on my Octavia Mk3 (2016). It reports the interface is out of date / this model is not supported.
    the guy who sold it is being quite helpful but is moving towards the 'You've damaged it, its not my fault' position So can anyone tell me if 19.6.0 actually works with the Mk3 Octavia - or is the question more complicated than that?
    thanks for any assistance
  5. #9485
    Jun 2018
    i have vagcom clone cable 18.2, i installed VCDS 18.2.0 and copied VCDSLOADER.exe to VCDS folder. i then plugged it into the car, the LED goes green, but when i hit test i get (Status: not plugged into the car). 20200425_010003.jpg20200425_010304.jpg
    Please advise how to solve this issue
    i tried VAGCOM_HWType, it reports no response and also when i use VAGCOM_EEWrite it says "Not in bootloader mode"
  6. #9486
    you have to upgrade it via USBasp, you will find the tutorial in the loader folder.
    Sent from my SM-G970F using Tapatalk
  7. #9487
    Jun 2018
    Thank you , i will search across this thread
  8. #9488
    Quote Originally Posted by engmoh980 View Post
    First try to write Fw+EEprom with an USB-ISP programmer. If ok, that is, if not:
    U3 have a stain on it. Is paint or is exploded? If exploded..complicate for you: must reprogrammed another new one and replaced.
    If not, try extract U10. Work? Lucky. Not work? Ft232R replace.
  9. #9489
    Quote Originally Posted by Rincewindwiz View Post
    Worked on your car and not work now?
  10. #9490
    Apr 2020
    Does someone has experience with this cable?
    https://www.obd2cartool.com/vagcom-2...anguage-p-1263
    It says it works with coming updates of VCDS so not a specific version.
    Also found this one:
    https://www.obd2cartool.com/diy-vag-...t-skoda-p-1317
    This one can read the MQB platform as wel.
    It’s mostly for my own car I will use the cable (Audi A4 Y2020) but i wil also use it on other cars from friend etc.
    Just looking for a decent cable who covers the most platform and is future proof.
  11. #9491
    Mar 2016
    Hello!
    Now I'm using the version 18.9.1 for VCDS, and I keep getting a "CAN: Not Ready" after hitting the TEST button. I've tried uninstalling and reinstalling both the software and the USB driver with different version (19.6.0, 18.9.0, etc.). I've tried different USB ports, different notebooks, different VAG cars (SKODA Octavia 2007, VW Polo 2012, VW Passat 2011 etc.)
    I did get it to successfully connect for a few times, but i just tried for about 30 mins, and kept getting the "CAN: Not Ready" message, and none of the diagnostics tools work. I have the cable buyed from here: https://www.obd2cartool.com/atmega-v...hipping-p-1554
    I've Restored Defaults, and everything. Nothing helps... Thoughts?
  12. #9492
    Top Poster jan4's Avatar
    May 2018
    somewhere in Belgium
    Who has a 1:1 cable ?? AND managed to get 20.4.1 working on it ??
  13. The Following 2 Users Say Thank You to jan4 For This Useful Post:
    Los Cuentos (27th April, 2020)
  14. #9493
    Default VAG-COM/VCDS EVERYTHING
    Hello every body Please have version 19.6.1 with loader 9.2
    Last Time on Audi A6 year 2013 engine like Sq5 have get no asam data missing
    And some other car like polo 2011 and golf 7 fonction mesured value case number 8 on Vcds are not available
    Does it normal ? There another best version fully working
    Thanks a lot
  15. #9494
    EU
    Quote Originally Posted by motorsport View Post
    Does it normal ?
    Please, use "Advanced measuring values". This is normal behavior for newer cars.
  16. The Following 2 Users Say Thank You to kaalis For This Useful Post:
    catalinosonesti (30th April, 2020), motorsport (30th April, 2020)
  17. #9495
    Quote Originally Posted by kaalis View Post
    Thanks a lot And for no asam data is missing ??
