Page 635 of 854 FirstFirst ... 135535585625630631632633634635636637638639640645685735 ... LastLast
Results 9,511 to 9,525 of 12803
  1. #9511
    May 2020
    sorry maybe a newbie question.
    which vcds version and vcdsloader version do i have to use to work with an hex-v2
    VID / PID : 0403 / FA24
    FT Serial : RT000001
    FT Description : Ross-Tech HEX-USB
    FT Chip ID : 0x90D448F6
    FW Version : 1.96
    HW Version : 0x46
    Identification : ROSS-USA
    SN : 0x00C70D754232
    Language : Chinese - ZHS
    Bootloader : Disabled
  2. #9512
    Quote Originally Posted by isavrseno View Post
    This old VCDS clone cable works with vehicles with k-line but on vehicles with CAN bus it can comunicate only with engine ecu
    Problem is hardware limitation (no CAN) or software related?
    Is a good cable, must work with K and CAN. If not, reflash. No CAN? Maybe defective one or bpth from MCP 2551/2515
  3. The Following User Says Thank You to liviudiaconu For This Useful Post:
    isavrseno (9th May, 2020)
  4. #9513
    Mar 2017
    Quote Originally Posted by syny0 View Post
    FW Version : 1.96
    HW Version : 0x46
    SN : 0x00C70D754232
    Bootloader is disabled. You have to reflash chip with programmer and then update with latest version.
  5. #9514
    Apr 2018
    Hello
    I have a request, maybe you will help, I have such a cable, unfortunately I had to replace the atmega. After the exchange can be programmed but no contact with the car. I need a diagram
    sorry for my English
  6. #9515
    Mar 2020
    Hello guys I have a question.
    If I buy chinese HEX V2 with software 19.6.1 will it work with 20.4?
    Is the cable different for these 2 versions or is it the same cable?
  7. #9516
    May 2013
    @krzysztof125
    before reprogramming have you cut the STC chip's leg or desoldered the STC chip?
  8. #9517
    Apr 2018
    I didn't do anything with STC, do I have to cut something?
  9. #9518
    Top Poster jan4's Avatar
    May 2018
    somewhere in Belgium
    read your pm please !!
  10. #9519
    Apr 2018
    thank you sorry I was at work I read when I came back, after applying to PDF INFO it still does not work
  11. #9520
    May 2020
    Quote Originally Posted by Xaby View Post
    Hey Xaby,
    thanks for the reply. Can i find anywhere a step by step guide, how to reflash the chip with a programmer? Would be awesome.
    greetz
  12. #9521
    Aug 2018
    France
    Hi Syny0,
    you can find all on first post of this thread. See kolimer package
  13. #9522
    Sep 2018
    can anybody tell me what the component D1 in the blue box is and if so do you know where i can get one or an equivalentt. The one on my board got burnt from over current.
  14. #9523
    Mar 2019
    Seems like it will be even more difficult to use the cable on new cars like the Golf 8
    https://www.docdroid.net/oAY2lJt/en-...al-for-umb-pdf
    https://forums.ross-tech.com/showthr...Protection-SFD
  15. The Following User Says Thank You to bg17aw For This Useful Post:
    markgo40 (11th May, 2020)
  16. #9524
    PSAcars's Avatar
    Oct 2015
    HOME
    Hello to all. To Mr. markgo40 D1 ( wg5 ) is PESD5V0S2BT.
  17. The Following User Says Thank You to PSAcars For This Useful Post:
    markgo40 (12th May, 2020)
  18. #9525
    Quote Originally Posted by bg17aw View Post
    For now looks that codding/adaptation/parametrization will be not possible with any third party tool as VCDS (including HEX-V2 or HEX-NET).
