bg17aw (31st May, 2020)
I suspect your FT to be damaged. See if is correctly writen and try again.
You can try directly write with EEWriter. If not work, uncheck "Autodetect VID/PID" and replace 24 with 20.
If not work, FT defective or Atmega defective. 90% FT defective. Can try write Atmega with USB ISP programmer, the communication can be interrupted by an altered firmware.
Experiments with genuine should be carried out with extreme caution.
FTDI chip is the crucial thing, which cannot be spoiled/lost/etc.
ATmega contents can be easily backed up and restored to other/replacement chip.
As for the remaining components - nowadays Chinese PCB are superior to the ones HEX Microsystems used a decade ago (lack of protective diodes, lack of CAN filters, etc...)
* MK100;
hi i have this cable an usbasp as i my bootloader is locked dose any have a tutorial for this cable plz i cant seem to find a step by step were is pin 9 i need to cut also as someone said about this have 9.2 folder but unsure what todo im confident with soldering etc here is my cable scan would like to use v20.4.1 thanks for your help
VID / PID : 0403 / FA24
FT Serial : RT000001
FT Description : Ross-Tech HEX-USB
FT Chip ID : 0x90D9FEB7
FW Version : 1.96
HW Version : 0x46
Identification : ROSS-USA
SN : 0x00C711A5C12A
Language : English only
Bootloader : Disabled
Simply desolder entire STC chip. This is better solution than cutting the pin.
* MK100;
subzdarg (29th May, 2020)
Im unsure how an cuting seems easyir Also can i just flash the cable or do i need to use the usb asp and flash it. Im a little confused as to where to solder the wires to read the chip with usb asp
also weres best to solder to on my board is it directly to the chip im a little confused to what pin power is on my mcp
please read the info/readme.pdf in kolimers zip , it will explain all to you .
Which pins should i put power on?
4 is ground and 16 is +12v?
Is that correct?
can anything be done with this cable or dose anyone know what this cable is for 20200531_130109.jpg
Can you explain how to see if it is correctly written?
I did try with Mprog and got the following results (serial is correct), please see picture
https://imgur.com/QOTme3A
Did you mean "which can be spoiled/lost"?
I have status "not plugged into car" while connected to the car.
I have this interface:
https://ibb.co/WP48L15
USBASP is on the way, but not sure if i have to connect also to 12V while connected to USBASP.
This guy in Russia only use 5V from USBASP.
https://www.drive2.ru/l/480983286789701679/
Only apply 12V power when you direct solder on the chips is kolimer telling in his readme file.
Is this correct?
Tnx.
I've connected the cable above the red vcds 168 an have a red flashing g led is this correct for programming ive removed the stc now also
