salut chef merci de ces informations ils sont super think you
Hello, to all, here are some real pro"s for 17usd pcb. Sorry i am not thinking the ugly way.
I understand the hobby's, i have it (real expensive one)
Today i have got vag-com 10.6 from china. But after install soft and drivers, i always get Cable not found. Is there any solution for it i can manage , or i will buy another one.
Thanks too everyone, it is pleasure too read your pro"s posts.
This is the way it worked always for me(before everything gone to hell)....after installing sw and drivers, plug ONLY usb... then after further "driver installation" run software and test the cable (just press OK and don't press save).
Then plug(already plugged into USB) it into car OBD port and press test - if everything is ok, press save...becuse when i had pressed "save" after plugging and testing only with usb plugged, after plugging into OBD and testing everything was OK except CAN bus....CAN ready was "not OK" or sth like that...Try that...you have nothing to loose
Can ready is ok only if car have Can Gateway, some older cars dont have it cca -2004
wanted dump for VCDS 10.6.3 .
Have Anybody that dump?
Can i make all this interface working just with power on OBD (on the bench)?????????
I know bout power source for Obd M8, i ask does it need JUST power source or something else. But ok , damn 17usd device. I will stop trying isn't worth the time.
Thanks to all.
