Page 650 of 854 FirstFirst ... 150550600640645646647648649650651652653654655660700750 ... LastLast
Results 9,736 to 9,750 of 12803
  1. #9736
    Feb 2014
    Heshamzn, for me the link is valid
  2. #9737
    Sep 2020
    Default cable not working
    https://postimg.cc/mPSt0xSb https://ibb.co/yFrjT87 Here are pictures of my clone. I new and need help with non working cable. I install vcds and drivers on win 10 and everything is worked fine. Now have problem, cable pass test in first screen vcds, but no enter to any modul (engine, transsmission, abs). Win 10 was on internet and is that reason for stop working? Is there any tutorial to make cable work? Thanks
  3. #9738
    Sep 2020
    https://ibb.co/VBh8hV3 Cant edit post
  4. #9739
    Apr 2018
    Quote Originally Posted by bing1 View Post
    Yes, you have to keep your cable as far from internet as you can
    Just roll back for a few pages, and you will find everything (tools and knowledge) in this thread. An easy and free to use app will solve your problem
  5. The Following User Says Thank You to Tib82 For This Useful Post:
    mullcom (7th September, 2020)
  6. #9740
    Aug 2012
    hi to all ...i have this clone....but ...
    unfortunately I no longer have the installation CDhow could I flash this?thanks in advance
  7. #9741
    Aug 2020
    Quote Originally Posted by Tib82 View Post
    About internet and cable. I think you can get both working. You only need to finding the ports that are calling home from the application.
    When I get my cable I going to put my router to work and try to finding out a way to block this ports or the application it self.
    Skickat från min SM-G973F via Tapatalk
  8. #9742
    Feb 2019
    Quote Originally Posted by sebage View Post
    What you need, firmware for the interface or software?
    Hello sebage, I need the software.
  9. #9743
    Aug 2018
    Romania
  10. The Following User Says Thank You to sebage For This Useful Post:
    seal777 (12th September, 2020)
  11. #9744
    Aug 2020
    Hello.
    I got my cable and usb programmer today.
    Can I download the software from brand and use loader 9.2 or are there some modifying software I need to download?
    Cable : vag196
  12. #9745
    Feb 2014
    Quote Originally Posted by mullcom View Post
    Hello.
    Cable : vag196
    can run original
  13. The Following User Says Thank You to belkor For This Useful Post:
    mullcom (9th September, 2020)
  14. #9746
    AB4S's Avatar
    Jan 2014
    Sheffield, UK
    Hi DK
    Is there a fix for Unsupported vehicle/missing ROD file?
    I am using HEX-V2
    Interface Ver 1.96
    Hardware Ver 0x46
    Best Regards
    AB4S
  15. #9747
    EU
    Which rod file?
  16. #9748
    hi
    im install vcds 20.4.1 from https://www.360diag.net/a/downloads/.../0610/585.html
    end not see rod file with VW Crafter 2019year, not read measured,no test output. loader is kolimer 9.2, database 25xxx files how fix the problem?
  17. #9749
    EU
    MFT, HGJ, ROJ, DRV, PCI and AIB 20.4.2 released
  18. The Following 2 Users Say Thank You to kaalis For This Useful Post:
    liviudiaconu (18th September, 2020), miouser (17th September, 2020)
  19. #9750
    Apr 2018
    Quote Originally Posted by kaalis View Post
    VCDS v20.4.2 (20200915 DS317.0)
    SHA1: 3f1db8400e5679622de2a22b6234505b61e36df2
    EXE is changed
    20.4.1 >> SHA1: a4ffd1f7a799a2fd9445f7b2864a63c9f636b842
    20.4.2 >> SHA1: 0b69143f68df50010155804580fa780ef96bd2b2
  20. The Following User Says Thank You to Tib82 For This Useful Post:
