Page 651 of 854 FirstFirst ... 151551601641646647648649650651652653654655656661701751 ... LastLast
Results 9,751 to 9,765 of 12803
  1. #9751
    Sep 2016
    Possible upload this file for update?very thanks
  2. #9752
    Sep 2016
    Quote Originally Posted by Fabio89 View Post
    friend
    I sent you a PM
    If you have file to update cable with VCIUPDATE
    My cable https://ibb.co/rdhWJx8
  3. #9753
    Mar 2020
    Czech
    I bought from here https://www.obd2cartool.com/vip-link...members-p-1209 Option 2/HEX-V2 cable.
    I installed VCDS 20.4.2 EN and VCDS 20.4.1 CZ (SVO) on a laptop with Windows 7 Pro 32bit (x86). The cable worked well. Now on this old laptop the charging module has broken and cannot be used. So I installed to the second older laptop with Windows 10 home 64bit (x64) again VCDS 20.4.2 EN and VCDS 20.4.1 CZ (SVO). When I first install on Win 10, Windows defender detected threats in Koliner loader, because is difficult to turn off completely Windows defender. I reinstalled VCDS with completely turn off antivirus. But the cable doesn't work quite well in this laptop with Win 10. The port test is OK for both VCDS (EN and CZ), License Status - Valid / Activated too.
    When I want perform SRI reset in my Passat B5 failure message is displayed. When I confirm this failure message with the OK button the service is set up and saved successfully.
    I have two questions.
    1 - You donīt know why this is displayed failure message?
    2 - When starting VCDS 20.4.2 EN with Kolimer loader v9.2 in a blue box I see x64 v9.2
    When starting VCDS 20.4.1 CZ (SVO) with Kolimer loader v9.2 in a blue box I see x86 v9.2
    It is good that the loader is starting x86 (32bit) when running on Windows 10 64bit system?
    Thank you for answer
    test port vcds en https://ibb.co/X8dyqBK
    test port vcds cz https://ibb.co/0np4BTV
    SRI Reset vcds en https://ibb.co/KVtRk2T
    SRI Reset en OK https://ibb.co/9W9Jbgn
    SRI Reset vcds cz https://ibb.co/VJB9XFZ
    SRI Reset cz OK https://ibb.co/tK6yBj6
    start vcds en https://ibb.co/zSPbsCy
    start vcds cz https://ibb.co/0ZZCzHC
  4. #9754
    May 2018
    Quote Originally Posted by Batch88 View Post
    I dont have the file too
  5. #9755
    Quote Originally Posted by jan zrok View Post
    [...] Windows 10 home 64bit (x64) again VCDS 20.4.2 EN and VCDS 20.4.1 CZ (SVO). When I first install on Win 10, Windows defender detected threats in Koliner loader, because is difficult to turn off completely Windows defender. I reinstalled VCDS with completely turn off antivirus.[...]
    Put exceptions in WinDefender for both VCDS.exe.
    After this see TREATS in Win Defender. A part of Loader is extracted in another location on HDD and is treat as virus. Ot treated job put exception too and will work
    Tip: When launch KoliLdr in Left-Down corner (South-West) of Loader screen must write OK. If not, loader not loaded correctly.
    For that users who moded loader for no splash screen..not appear that "OK" i speak
  6. #9756
    Sep 2016
    Thanks,but have found a solution for update this cable? thanks
  7. #9757
    Sep 2015
    Hi mates.
    Do you have solution for License revoked ? I used VCDS 19.6.1 , 19.6.2 and 20.4.1 with Kolimer loader 9.2 and after a while the license will be revoked.
  8. #9758
    Nov 2018
    IMG_20200919_091814[1].jpgIMG_20200919_091845[1].jpgI bought this cable a while back but the hard drive crashed on the laptop that had the software and the loader. Can someone look at the pictures and tell me which software and steps to take to use it on a 2004 VW. Thanks in advance for any help you can give me. P.S. My current laptop runs Windows 7.
  9. #9759
    EU
    And again, new @%@^T@^ released yesterday for MFT, HGJ, ROJ, DRV, PCI and AIB
    PRI also got updated.
  10. The Following 2 Users Say Thank You to kaalis For This Useful Post:
    jan4 (23rd September, 2020), miouser (23rd September, 2020)
  11. #9760
    Sep 2020
    IMG_5033.JPGIMG_5015.JPGIMG_5018.JPGIMG_5022.JPGHi guys I’ve got what I bought and was advertised as a hex v2 cable. I need it to work with 2020 cars. When I plug into and use the interface vcds reports it as a hex-usb interface not v2.
    Can I update? I’ll attach pics that might help
  12. #9761
    Sep 2020
    May 2009
    hi frend I have problem after update my vcds can help please ...
  14. #9763
    Top Poster jan4's Avatar
    May 2018
    somewhere in Belgium
    @ hrag
    which cable ?
    which update ?
  15. #9764
    May 2018
    @ j8y
    NO........!!
  16. #9765
    Dec 2018
    what is the latest version of Kolimer loader?
