Page 657 of 854 FirstFirst ... 157557607647652653654655656657658659660661662667707757 ... LastLast
Results 9,841 to 9,855 of 12803
  1. #9841
    Jan 2020
    Latest Version DRV 20.4.2. DS317.0 20200919 from the official website doenst work with loader 9.2
    While the loader splash screen there´s no OK coming and then vcds does not start. The splash screen disappears and nothing happens.
    Does anyone have the version DRV before ? 20.4.2 from august or something ?
  2. #9842
    Apr 2008
    The natural question follows: STM32F415 version can do older as well as newer cars but costs a little more.
    Is there good and bad versions of the atmega. Any idea (roughly) what year the atmega begins to struggle.
    I also dont understand why aliexpress offer so many different versions of VCDS. Why would you not just use the most up to date version that functions with your hex-v2 20.4.2
    something like in this link: https://www.aliexpress.com/item/4000...archweb201603_
    But I see it shows two different versions of board for the same product
  3. #9843
    EU
    Quote Originally Posted by bnfghmjkljkhiu View Post
    Solve the problem with antivirus by excluding these files from it:
    vcdsloader.exe
    %temp%\vcds_hook.dll
    %temp%\vcdsloader64.exe (if using 64bit vcds)
  4. #9844
    Oct 2020
    @phester those are not two boarda, just two sides of boards. ATMEGA usually should work with cars until MY 2017/2018, depends on specific car you are working on
  5. #9845
    Apr 2008
    Quote Originally Posted by dixonSRB View Post
    Thanks for the reply but have a second look. I know that each picture shows a split view of top and bottom. There are two separate pictures of boards 3rd and 5th pic. One has a wired cable and the other has s USB socket. They both have a Atmega micro on them separately.
    Is there any reason not to just use 20.4.2 for all cars?
  6. #9846
    Apr 2017
    anyone have the 17.1.3 v2 loader link? i cant download for some reason from here!
  7. #9847
    Aug 2020
    Quote Originally Posted by Kapten View Post
    You can use the loader HERE
    HaynesPro 2025 online + AC/ Delphi 2022.02a available, message for where to get them!
  8. The Following User Says Thank You to crouchinggerbil For This Useful Post:
    r3aperx (17th November, 2020)
  9. #9848
    Jan 2020
    Quote Originally Posted by kaalis View Post
    vcdsloader.exe
    The problem was solved to start the loader as an admin because I installed it in "programm dir" noch Ro§§-tech dir. Thanks !
  10. #9849
    Col19's Avatar
    Jan 2019
    France
    Hello kings
    Is there a way to flash the STM32 to have access to other languages ​​like French ....?
    Thank you.
  11. #9850
    Mar 2016
    which version use your STM cable ?
    because if it was delivered with version 20.4.2 you need to use the loader VIIPlusLoader ship with the STM Cable.
    - install the French version (or any other language)
    - drag&drop the desktop shortcut into the loader
    and always use the loader for start the French Version.
    Bye
  12. The Following User Says Thank You to mrle9 For This Useful Post:
    Col19 (25th November, 2020)
  13. #9851
    Apr 2019
    Will this work in v20.4.1? There is no Loader in this version. Can version 20.4.1 be run through Loader at all?
  14. #9852
    Aug 2020
    Quote Originally Posted by ESPRIT View Post
    Yes and the 20.9 beta works with the loader
  15. The Following User Says Thank You to crouchinggerbil For This Useful Post:
    ESPRIT (23rd November, 2020)
  16. #9853
    Apr 2019
    STM cable and VIIPlusLoader ? can I also change the language version, I only have En language.
  17. #9854
    Aug 2020
    https://rosstech.fr/content/6-telechargements Nobody know how to google anymore?
  18. The Following User Says Thank You to crouchinggerbil For This Useful Post:
  19. #9855
    Apr 2019
    I have a Chinese cable with an STM chip.
    The problem is that VIIPlusLoader doesn't even start on version 20.4.1 that I got from the seller.
    I have a "Cable is locked" message at Loader startup.
    I think I have Non Upgrade available version and I can only run it on the seller's software.
    With vcds 20.4.1 works fine without Loader.
