Page 65 of 854 FirstFirst ... 1555606162636465666768697075115165565 ... LastLast
Results 961 to 975 of 12803
  1. #961
    Dec 2010
    Quote Originally Posted by ivanxxx View Post
    Can ready is ok only if car have Can Gateway, some older cars dont have it cca -2004
    I know...but on the same car didn't work normal procedure(saving configuration after testing usb cable and then plugging into OBD)...and after procedure explained above...it worked...it sounds like a very stupid reason...but who cares if it worked
  2. #962
    Aug 2010
    think you bibkar
  3. #963
    Newbie ciamardo's Avatar
    italy
    hi guys i found my old interface 908 from DX
    but the pin(red line) are not solder
    Same interface found in DK Forum
    Original Vag-Com HEX-USB+CAN Rev.B from Ross-Tech...
    ELM 327 chinese with 1.4b "genuine" soldering pic!!!
  4. #964
    Oct 2008
    On Earth
    Pin 1 and 8 not used but maybe it is to be stable ( I mean between PCB and the diagnostic OBD 16 pins connector ). Not necessary to solder that pins becasue item aren't used.
    Good luck
  5. #965
    DK Veteran bibkare's Avatar
    B & H
    Default VCDS hardware
    I just wanna show you this kind of VCDS hardware, it's pretty unusual, it has FT232RL but there is no STC chip and no matter which dump i put in, it could only work on VAGCOM 704 even though it came as version 908. Maybe some of you had same experience. It still works with 704 and works great
  6. #966
    Oct 2008
    On Earth
    Quote Originally Posted by bibkare View Post
    Does it work with 908?
    Did you tried with that modified sw?
    Good luck
  7. #967
    Aug 2010
    Hi! I have received last week, some china 10.6 cable. I have read all the topic, and i'm a little bit disapointed about the 10.6 interface.
    But I have a question regarding 10.6 and Windows 7 64bits. My interface is 1.81 firmware, it's work with 10.6.0 version, all it's ok, but it's not work on Windows 7 64 bits, They give me an error message. But if I check on the ross-tech web site, the 10.6.0 version suppose to work with 64 bits OS.
    Do you have an idea of the problem?
  8. #968
    Oct 2008
    On Earth
    Quote Originally Posted by slevesque View Post
    You have logging in as Administrator
    Everything works like a charm on W7 64 biti ( tested by me )
    Good luck
  9. #969
    Aug 2010
    They received the same message
    you must run the 64-bit DPInst.exe on this computer Contact the vendor
  10. #970
    Oct 2008
    On Earth
    So you couldn't install the driver?
    I suppose so.
    Install it manually
    The folder of driver it is the same one where is the VCDS installed.
    C:\Ross-Tech\VCDS
    Good luck
  11. #971
    B & H
    Quote Originally Posted by mattydr67 View Post
    Good luck
    it worked like 2 times with 908 soft and then died, chinese finest
  12. #972
    Oct 2008
    On Earth
    Did you tried to reprogramm it again?
    Good luck
  13. #973
    brasil
    Default Outline vcds812
    Hello it would like a help my cable it loosened the threads usb of the plate ,mais I am not sure of the connection somebody it can me to help.
    Thank you
    Pedro
  14. #974
    brasil
    Default Excuse he/she didn't leave the image
  15. #975
    Member ironderek's Avatar
    Quote Originally Posted by PEDRO4053 View Post
    Counting from the GAL16V8(right side):
    red-green-white-black
