Page 663 of 854 FirstFirst ... 163563613653658659660661662663664665666667668673713763 ... LastLast
Results 9,931 to 9,945 of 12803
  1. #9931
    Oct 2020
    You just update it through VIIPlusLoader? It updates automatically? And of course following this thread for new versions of both VCDS and VIIPlusLoader
  2. #9932
    Nov 2020
    Quote Originally Posted by dixonSRB View Post
    Update firmware by VIIPlusLoader automatically and use Ross-tech vcds hex-v2 the latest software directly.
  3. The Following User Says Thank You to flyfvdi For This Useful Post:
    Col19 (11th December, 2020)
  4. #9933
    Quote Originally Posted by cebbes30 View Post
    Hello All,
    Is there a clone hex V2 working with VW Golf 8.
    Can you read the 4B, D6, D7 and other modules.
    If yess can anyone give me link
    Here: https://www.aliexpress.com/item/1005...archweb201603_
  5. #9934
    Top Poster nicolas2015's Avatar
    Feb 2015
    somewhere in cornwall
    I have this VCDS 19.6.2 working with kolimer loader, any idea if it;s safe to upgrade to last version?https://www.obd2cartool.com/vip-link...kt5hmlc2js9tu3
    Vag-com, Op-com, Focom, Autocom,Multidiag, Forscan, Lexia....
  6. #9935
    Quote Originally Posted by nicolas2015 View Post
    Yes! i already updated to 20.12 with the same cable and kolimer loader and it works without any issue
  7. #9936
    Nov 2020
    update firmware through VIIPlusLoader automatically.
    download the latest vcds hex v2 software from www.ross-tech.com.
    use it directly.
  8. The Following User Says Thank You to flyfvdi For This Useful Post:
    jan4 (11th December, 2020)
  9. #9937
    Apr 2018
    Does anybody know what is the difference between these releases? The newer installer is bigger with 1,7 MB
    Can both of them use the v9.2 or only the earlier version?
    20.12.0 ENG (20201124 DS322.0) >> SHA1: cd68cfc2b1267993f22c713df5ba9c773b4b3e5c
    20.12.0.1 ENG (20201125 DS322.1) >> SHA1: 92824a6903b726b42a4e8ca79eba3252aa3f6afb
  10. #9938
    DK Veteran WOODWARD395's Avatar
    Manchester UK
    Sorry if it's been asked before
    Anyone got a link to hex v2 cable with STB chip is that the best one for vag do they update themselves or is software needed thanks
  11. #9939
    EU
    Quote Originally Posted by Tib82 View Post
    difference of rod files in uds_ev folder + lcode classic version added.
  12. #9940
    Quote Originally Posted by WOODWARD395 View Post
  13. The Following 2 Users Say Thank You to safm For This Useful Post:
    alin 151 (14th December, 2020), WOODWARD395 (16th December, 2020)
  14. #9941
    Nov 2020
    i saw your vcds hex-v2 on aliexpress with main chip STM32F405VGT6
  15. #9942
    Oct 2019
    I read some topics here but random , so please escuse the question:
    for STM 32 seems that are different pcb layouts and different (or missing components). I was told that 32F405 can be updated , etc
    what is the ok PCB version ? many many thanks
    or this version ,
    many thanks
  16. #9943
    catalinosonesti's Avatar
    Mar 2019
    east nord pole
    hello ,i think i posted in corect place ....
    i need help to adaptation or codind ABS module for a passat 2006 motor code BMM.
    i don t know what is the problem with this car ,only thing coustumer tell me he try to change the brake module ,then he have the error ABS,ESP ,STERING .
    So i try to coding ABS module with vcsd ,i loget with 40168 , everithig ok till i read { measuring bloks 08} group 04 field 1 i have 0 and no move of 0 ,i move the stering buo still show me 0 .
    change the stering module {same code } but no work ,i have same 0 .
    is there another metode to code this module .
    here i put the log file from vcds .
    thank all for your time and help '
    best regrads
  17. #9944
    Nov 2020
  18. #9945
    Nov 2020
    Quote Originally Posted by brmservice View Post
    or this version ,
    many thanks
    same pcb, same one company vcds hex-v2.
