brmservice (14th December, 2020)
many thanks , now I have this one (Atmega 162) and I`m using oficial sofware (from vcds servers) + loader , but has some bugs like on instruments long coding I don`t have nothing in the first bits .... beside this is working ok , it`s activated but some times for some functions is showing "need licence for this function"....
I need a fully functional tool and I wonder if this hex-v2 will work ok because I also consider to buy genuine tool. thanks again
help pls after 2 time use i got this message: invalid/unauthorized,atmega chip hex 2,that message i got it both on 2 soft 20.4.2 and 20.12
vcds hex-v2 with main chip ATMEGA16216AU 1436H is actually vcds hex-v1, the LOADER just changed the display.
brmservice (16th December, 2020)
Hi.
I have a vcds hex v2 clone, i used to run it with vcds 16.8 that the producer send to me.
I lost the software.
i tried the last files from here but none of them worked.
Does anybody know what i have to try?
I attached pics with pcb for help.
Thank you
You can find most releases HERE thanks to user XTR for sharing.
Is there any indication of what kind of chip that is in the middle?
HaynesPro 2025 online + AC/ Delphi 2022.02a available, message for where to get them!
brmservice (15th December, 2020), Col19 (29th December, 2020), tsek (14th December, 2020), vm44 (5th January, 2021)
Your central chip contain 64pin package. ATMega 162 contain 44pin.
No way to run it on non-dedicated software. Only buy a new one.
The chip is erased unfortunately. I will try some releases... I think is STM32F405. VIIPlusLoader is not recognize it but i tried vcds 16.8.3 alone and running fine. Do you think i can use a more recent version?
