Page 665 of 854 FirstFirst ... 165565615655660661662663664665666667668669670675715765 ... LastLast
Results 9,961 to 9,975 of 12803
  1. #9961
    Aug 2020
    hello,
    Have someone problem like this with hex v2? Stm chip.
    It say illegal device. The device is locked.
    https://imageupload.io/QYFjKbfQ9U.i
  2. #9962
    Nov 2020
    Quote Originally Posted by flyfvdi View Post
    you open the shell, please check ,what is the main chip ?
    hi,my cable its with ATMEGA162+16V8+FT232RQ,when i conect only on pc its show ok and fund module,but when conect on the car and test its show no module fund and : invalid/unauthorized,the cable its new and i use only 2 times
  3. #9963
    Mar 2016
    Did you copied VCDSLoader.exe in the VCDS directory and did you used it for start the software ?
  4. The Following User Says Thank You to mrle9 For This Useful Post:
    Col19 (29th December, 2020)
  5. #9964
    Apr 2019
    Has version 20.4 restored "OEM ATMega162" cable banning if you have an active Internet connection when you start the program?
    "OEM STM32F415" was banned always.
  6. #9965
    Nov 2020
    Quote Originally Posted by mrle9 View Post
    yes sure,2 times its work all ok
  7. #9966
    Nov 2020
    Quote Originally Posted by ESPRIT View Post
    no i not use internet on this pc never
  8. #9967
    Apr 2019
    And you have not installed a different language version?
  9. #9968
    Nov 2020
    no my friend,i not do anything,i heave a laptop only for vcds so i not connect this laptop on internet,the cable its arrived.i do all nedet thinks,no internet,no antivirus,all ok.i try both versions 20.4.2 and 20.12.and its work fine,all ok,when i go again on the car the next day then shoiw that messages
  10. #9969
    Aug 2020
    Quote Originally Posted by GOLF 5 View Post
    I had the same problem when i upgraded from 20.4.2 to 20.12.
    What i did was run "Mprog.exe" then click on TOOLS then Read and Parse. This will read your device.
    Then Click on the folder on top left to open templates and select VCDS_FA24_ftdi_RLRQ.ept for FT232R chip
    Then click on Device then Program or click on the lightning button to reprogram your lead.
    This worked for me on atmega hex v2.
    Try and report
    HaynesPro 2025 online + AC/ Delphi 2022.02a available, message for where to get them!
  11. The Following 3 Users Say Thank You to crouchinggerbil For This Useful Post:
    Col19 (16th December, 2020), GOLF 5 (15th December, 2020), seal777 (4th January, 2021)
  12. #9970
    Nov 2020
    Run the loader as an administrator
  13. #9971
    Nov 2020
    My VCDS Hex-V2 with main chip STM32F405VGT6, it is working like charm, great!
  14. #9972
    Nov 2020
    Quote Originally Posted by andreas11 View Post
    hello,
  15. #9973
    Dec 2020
    VCDS Hex-V2 with main chip STM32F405VGT6 can work with all ross-tech version softwares
  16. #9974
    Nov 2020
    hello,
    Please contact VCDS Hex-V2 with main chip STM32F405VGT6 factory FLY Comapny
  17. #9975
    Nov 2020
    VCDS-Release-20.12.0-Installer and VIIPlusLoader-08.020.13-EN-Installer already released, download from this mega.nz link :
    https://mega.nz/file/Q5VzEYJL#LkuxoJ...sKGA6gdkKWfu8o
  18. The Following 10 Users Say Thank You to flyfvdi For This Useful Post:
    Achtuhr (16th December, 2020), adrianoo (1st January, 2021), brmservice (16th December, 2020), Col19 (29th December, 2020), nicu1979 (16th December, 2020), olivier8877 (16th December, 2020), sep382 (19th January, 2022), velislav25 (19th December, 2020), vm44 (5th January, 2021), winamax69 (17th December, 2020)
