Page 668 of 854 FirstFirst ... 168568618658663664665666667668669670671672673678718768 ... LastLast
Results 10,006 to 10,020 of 12803
  1. #10006
    no croatian lang vcds 20.12.0 all lang
    no release croatian exe
  2. #10007
    Mar 2016
    @jach0o : I buy mine here and it work fine but all clone didn't have component in the red square as you want, it is only on original at the moment
  3. #10008
    Jul 2018
    Hi guys,
    I have a HEX-V2 clone with STM32 F415 and it doesn't connect to all modules. An Atmega interface connects without problems on all modules of the same car (Seat Ibiza 6j 2010).
    I'm using original VCDS 20.4.1 English, as advised by the AliExpress seller.
    I can connect to engine, which uses KWP200, I can also connect to Central Electric, which used CAN, but I can't connect on ABS and Instruments. It seems like the problem is related to the UDS protocol.
    Did any of you have the same problem? Any suggestions?
    Thanks!
  4. #10009
    Apr 2019
    Quote Originally Posted by mrle9 View Post
    The item in the red frame from post # 9975 it is the buzzer. It has no nessecarry for correct operation, beeper turns on after the diagnosis is completed, so that the service technician does not forget to remove it from OBD Socket after the end of work.
  5. The Following 3 Users Say Thank You to ESPRIT For This Useful Post:
    Bastard2 (12th January, 2021), kaalis (18th December, 2020), mrle9 (18th December, 2020)
  6. #10010
    please if anyone has a vcds release and loader with with
    croatian, bosnian or serbian language to post a link.
    i have vcds 20.12.0 with loader v9.2
    but there are no such languages.
    thank you in advance
  7. #10011
    Oct 2019
    edit by user
  8. #10012
    Nov 2020
    Quote Originally Posted by jach0o View Post
    May I ask where to buy proper hex V2 clone ? With STM stuff and red square chip?
    I found here similar:
    https://www.obd2cartool.com/diy-vag-...t-skoda-p-1317
    I didn't tried them - (is the photo of genuine or clone that they sell?) Still it's 50+12 for shipping ? Any cheaper?
    Where is that blue board one?
    Buy VCDS Hex-V2 from aliexpress
    https://www.aliexpress.com/item/1005...6bae4edfKNwPWm
  9. #10013
    Nov 2020
    Quote Originally Posted by ireun View Post
    Not really, the layout is different, one component is not missing..
    Wysłane z mojego ONEPLUS A5000 przy użyciu Tapatalka
    belong to same one company, with main chip STM32F405VGT6
  10. #10014
    Nov 2020
    The blue one is the ORIGINAL VCDS board. I just wanted to let the people see what components are on the genuine PCB.
    The original ross-tech vcds hex-v2 used blue pcb before, now it is using green pcb.
  11. The Following User Says Thank You to flyfvdi For This Useful Post:
    ireun (19th December, 2020)
  12. #10015
    Nov 2020
    Hmm, therefore the green one witch I found in previous post are green with this red square component are the nearest to genuine ? Is there any safe reseller or best place to buy one?
  13. #10016
    Nov 2020
    Quote Originally Posted by nextor View Post
    Hi guys,
    Thanks!
    VCDS Hex-V2 with main chip STM32F405VGT6 can work well with the UDS protocol
  14. #10017
    Nov 2020
    Quote Originally Posted by kladusa View Post
    VCDS hex-v2 is also available in the following languages:
    Chinese, Croatian, Czech, Danish, English, French, German, Hungarian, Italian, Polish, Portuguese, Romanian, Russian, Spanish, Swedish
  15. #10018
    Nov 2020
    the black square component is buzzer, be dispensable
  16. The Following User Says Thank You to flyfvdi For This Useful Post:
  17. #10019
    Russia, Moscow
    Quote Originally Posted by flyfvdi View Post
    So you have a buzzer installed?
  18. #10020
    Nov 2020
    Quote Originally Posted by AYD View Post
    yes, VCDS Hex-V2 with main chip STM32F405VGT6 and the black square buzzer
