Page 669 of 854 FirstFirst ... 169569619659664665666667668669670671672673674679719769 ... LastLast
Results 10,021 to 10,035 of 12803
  1. #10021
    Dec 2020
    Hi everyone,
    Ik have a question about my Vag com cable. I bought a cable + software from somebody. During installation and testing my laptop was connected to internet. The first time I tested the interface, the license was correct and working. Unfortunately, the second time it did not work anymore due to an unauthorized license... Probably the interface was connected with internet and has ‘updated’ itself... Does anyone know if it is possible to ‘undo’ this? Or to replace the firmware of the interface?
    Thank you!
    1289
  2. #10022
    Feb 2017
    Quote Originally Posted by 1289 View Post
    Hi everyone,
    Thank you!
    1289
    Remove the cover from the cable and take a picture of the PCB board. Upload it somewhere and share. It depends on what type of chip is used in your cable.
  3. The Following User Says Thank You to ireun For This Useful Post:
    1289 (20th December, 2020)
  4. #10023
    Dec 2020
    Thanks for the quick reply.
    Here is the picture of the PCB board.
    1289
  5. #10024
    Dec 2020
    And the pic of the cable
    Thanks!
    1289
  6. #10025
    Top Poster jan4's Avatar
    May 2018
    somewhere in Belgium
    This one baffled me , is there anyone who knows the answer ,
    win7 32 bit loader 9.2 vcds 20.12.0/1 only respose on all found modules ;
    Unsupported vehicle.Please upgrade to a current Ross-Tech interface.
    No ASAM data for: "EV_Brake1UDSContiMK100IPB" ()
    same cable on win10-64 same loader 9.2 , same vcds 20.12.0/1 and this is the result ;
    ASAM Dataset: EV_Brake1UDSContiMK100IPB 037009
    ROD: EV_Brake1UDSContiMK100IPB_037_SK37.rod
    No fault code found.
    so i am sure cable and software are ok , BUT why is it not working in this win7 32 laptop ??
  7. #10026
    Oct 2017
    Can someone say what the difference is between hex v2 STM415 vs STM405, I mean the arm chip is slightly different, but they have different hex loaded? Or the loader work differently? Does vcds check which chip or just use functions in the arm hex code?
  8. #10027
    Hi everyone,
    I have a Hex V2 based on ST32F415. It worked only a few times (maybe once). Now It can't connect to any module. It test correctly but no connection to any module. I tried the VPI loader but says illegal or something like that. Obviousely because it works only on ST32F405. My question is, If I replace the ST32F415 chip with ST32F405 available on sale in the internet will it work knowing it's sold virgin?
    Here is the link to chip on sale in AliExpress:
    https://www.aliexpress.com/item/4000...c00CSVJ7K&mp=1
  9. #10028
    Nov 2020
    Hi everyone,
    Thank you!
    1289
    fake vcds hex-v2, it is actually vcds hex-v1
  10. #10029
    Nov 2020
    Quote Originally Posted by bedrock View Post
    VCDS Hex-V2 with main chip STM32F405VGT6 work with VIIPlusLoader-08.020.13-EN-Installer now
  11. #10030
    Nov 2020
    Quote Originally Posted by anass_f View Post
    Hi everyone,
    VCDS V2 english software version is v20.4.2 is chinese company tool, the best in the world
  12. #10031
    Mar 2018
    Quote Originally Posted by jan4 View Post
    Compare 2 LogLoader files from both systems, most likely it writes to 32-bit - Not Found
  13. #10032
    Nov 2020
    Quote Originally Posted by Roma77 View Post
    too complicated
  14. #10033
    Apr 2019
    ... My question is, If I replace the ST32F415 chip with ST32F405 available on sale in the internet will it work knowing it's sold virgin?
    No.
    Serial number is writed to OTP area -One Time Programing.
    See DS150E repair, some chip: STM32F207
  15. #10034
    Thank you for your explanation. Regarding the OTP, at least it permits writing one time. Why not use that one time to write the SN?
    If it's feasible, can I read the full dump (including the OTP) from an other VCDS with 405 chip and then write it back to the new vergin chip?
    @flyfvdi
    I'm sure you're aware that a VCDS with ST32F415 is definitly a Hex V2 and not a fake V1. I don't know why you say what you said!!
  16. #10035
    Jun 2019
    somebody has a pinout to connect this to usbasp?
