Page 676 of 854 FirstFirst ... 176576626666671672673674675676677678679680681686726776 ... LastLast
Results 10,126 to 10,140 of 12803
  1. #10126
    @flyfvdi can you share the Source of VII Plus loader? not the compiled loader.
    Sent from my SM-G970F using Tapatalk
  2. #10127
    Dec 2017
    Quote Originally Posted by badrax View Post
    More updates
    Serial number used by my clone is:
    hv21b04-000059-233fed-b8bd54-vliahh-5a6c (Using VCDS 20.4.1)
    hv21b04-000059-233fed-b8bd54-vchahh-5a22 (Using VCDS 20.12.0)
    One part is changing and that is this "vchahh"
    It looks like that this part is the VCDS version number and does not contain info about the cable itself.
    Can anyone confirm this by testing with multiple versions of VCDS?
    I also have "vchahh" on my ATMEGA 162 cable at VCDS 20.12.0.
  3. #10128
    Top Poster jan4's Avatar
    May 2018
    somewhere in Belgium
    Quote Originally Posted by AndreaEl View Post
    Link in txt
    THANKS !! ,
  4. #10129
    Dec 2020
    Anyone have access to linux that could list out the descriptors for the cable that support updates
    First find the device by using "lsusb". You should see a device with the VIP:PID 0483:a0cb.
    Next run "sudo usbhid-dump -e descriptor -a 2:41" and replace with your bus and device id
    ex.
    lsusb -> Bus 002 Device 041: ID 0483:a0cb STMicroelectronics
    sudo usbhid-dump -e descriptor -a 002:041
    06 00 FF 09 01 A1 01 85 01 09 08 15 00 26 FF 00
    75 08 95 3F 91 00 85 02 09 09 15 00 26 FF 00 75
    08 95 3F 81 00 C0 09 02 29 00 01 01 00 A0 FA 09
    04 00 00 02 03 00 00 00 09 21 11 01 00 01 22 26
    00 07 05 81 03 40 00 0A 07 05 01 03 40 00 0A 00
    55 8E 01 08 5F 8E 01 08 8B 8E 01 08 69 8E 01 08
    9F 8E 01 08 C1 8E 01 08 E3 8E 01 08 12 01 00 02
    00 00 00 40 83 04 CB A0 00 02 01 02 03 01 0A 06
    00 02 00 00 00 40 01 00 04 03 09 04 01 00 00 00
    67 8F 01 08 69 8F 01 08 7B 8F 01 08 83 8F 01 08
    8B 8F
    And see if your output is the same as I get on both the 415 cable and on the 405 (non upgradable)
  5. The Following User Says Thank You to badrax For This Useful Post:
    Col19 (11th January, 2021)
  6. #10130
    Nov 2020
    Quote Originally Posted by mrben View Post
    sorry , my friend, wo do not have the Source code of VII Plus loader
  7. #10131
    Nov 2020
    VCDS Hex-V2 with main chip STM32F405VGT6 Software for other languages
    https://mega.nz/file/g09yXDiR#exlbFg...yMyipYXXjr0lic
  8. The Following 4 Users Say Thank You to flyfvdi For This Useful Post:
    AYD (9th January, 2021), Col19 (11th January, 2021), seal777 (6th January, 2021), vm44 (7th January, 2021)
  9. #10132
    Mar 2019
    If i have actually VCDS 20.4.2 with ATMEGA can i safe update to 20.12 with VCDSLoader?
  10. #10133
    Jan 2019
    Quote Originally Posted by flyfvdi View Post
    For the VII Plus loader, it would be great if you could choose which version you want to run if I have more installed. For example 20.4.2 CZ or 20.12 EN. If you had the opportunity to work on this with the producer, you would certainly be grateful to a lot of people
  11. #10134
    EU
    Quote Originally Posted by MaTyyyspl View Post
    Sure, you can.
    Sent from my SM-J510FN using Tapatalk
  12. The Following 2 Users Say Thank You to kaalis For This Useful Post:
    Col19 (11th January, 2021), mindafuttu (7th January, 2021)
  13. #10135
    Mar 2019
    Quote Originally Posted by kaalis View Post
    Sure, you can.
    Thank you, i updated without any problems, but i still dont see labels in long coding..
    https://imgur.com/a/X5LOlOw
    Any ideas? :/
  14. #10136
    @martyyyspl this means that the corresponding lbl/cbl file for the choosen module is missing from vcds, you have to find it and add it to see description in long coding.
  15. #10137
    May 2018
    this function is already embedded in the loader .
    Quote Originally Posted by neccccro View Post
  16. #10138
    Mar 2019
    but where i can find it? its Audi A4 B9, i tried 17.13, 19.6, 20.4, 20.12 and always get this error... :/
  17. #10139
    on audi forums, if someone made it/create it
  18. #10140
    ex.
    8B 8F
    I have received mine from this URL : « 2020 Newest VCDS HEX V2 Interface VAGCOM 20.4.2 VAG COM 20.4 FOR VW AUDI Skoda Seat VCDS 20.4 English German STM32F405 ARM Chip ».
    I have not used the interface for the moment, so, maybe the output is not accurate...
    bigbob@bigbob-UX31A:~$ sudo usbhid-dump -e descriptor -a $(lsusb | grep STMicroelectronics | awk '{print $2":"$4}' | awk -F ':' '{print $1":"$2}')
    003:017:000:DESCRIPTOR         1609871552.427438
     08 95 3F 81 00 C0
    Hope it help...
  19. The Following 2 Users Say Thank You to Creteil For This Useful Post:
    badrax (5th January, 2021), Col19 (11th January, 2021)
