Page 678 of 854 FirstFirst ... 178578628668673674675676677678679680681682683688728778 ... LastLast
Results 10,156 to 10,170 of 12803
  1. #10156
    Where i'm wrong?
    Installed last V II loader, 20.08.13.
    Launch loader, say update, updated. But not offer me version of VCDS choose (Offered me long time ago, only one time) and when i drag and drop VCDS.exe from ROJ lang try to launch and "Software startul failure".
    With any old version is the same. Cables are with 405.
    In VCDS 20.12.0 EN work well
    Tried to uninstall loader and reinstall but nothing.
    How can determine loader to offer me the choose vcds version?
    The same on W7 64 and W10 64
  2. #10157
    Apr 2019
    Quote Originally Posted by kaalis View Post
    @Esprit, Does it have atmega162 inside? ...
    No, STM32F415 inside
  3. #10158
    Top Poster jan4's Avatar
    May 2018
    somewhere in Belgium
    @liviudiaconu
    drag your vcds desktop icon onto the loader surface on your desktop ( when the loader is active ) , and it will start that version .
  4. #10159
    Apr 2019
    Cable works fine without Loader, but only 20.4.1-EN wersion.
    I try use 20.12-EN with this cable but Kolimer loader not work (hangs) and VIIPlus loader says Illegal cable.
    It is possible at all ?
  5. #10160
    May 2018
    Quote Originally Posted by ESPRIT View Post
    NO .............
  6. #10161
    Dec 2020
    I am atm trying to make my own tool to communicate with the cable to make thinks a bit more easy.
    The first stage of the communication is to agree on a 256 bits AES key to use for the rest of the session.
    This key (there are in fact 19 of the) was also changed from my 415 / 405 cable to the upgradable one so I needed help from a forum member to extract this info.
    But the best way would be to make the tool support this and there is one more function I need to reverse to complete this task.
    Since I am working with the loader and have the key it's not to important and I wont spend time on this algo atm but if anyone else want to join in and helt that would be great.
    So the cable sends 0x80 (128 byte 1024bit) to vcds.exe and this data is now decrypted/encrypted (depends how you look at it) using RSA1024. The 256bits' AES key is now derived from this data by calling a function that will return this AES key. I need someone to have a look at this function and figure out how this is done.
    Use the unpacked version of vcds (20.12) and thanks to whom ever unpacked this exe coz this helped speed things up
    At address 0x4B56DC is the function that will extract the AES key from RSA-C
    In this function there is a call to RSA decrypt
    0x004B5736 call rsa_decrypt(rsa_c, len, v11, &rsa_ses, 0, a7);
    and the decrypted rsa data (rsa-m) will be returned in "rsa_res"
    below this then this function is called
    0x004B575E call sub_4B5377(v11, rsa_ses, a6, aes_key, a5, key)
    and uses the decrypted rsa data and derived the aes key from it.
    If someone could have a look at this function then that would be great..
  7. The Following 3 Users Say Thank You to badrax For This Useful Post:
    BASi77 (10th January, 2021), ccr64k (9th January, 2021), Col19 (11th January, 2021)
  8. #10162
    Quote Originally Posted by jan4 View Post
    @liviudiaconu
    Exactly this i made and i obtain an error message: Software startup failure. No metter the version of loader or the version of ROJ soft.
    In the past i has an ARM cable working in SVO language. Tested here, loader offered me the soft i want, and worked. From that momment not another regional soft working on an ARM cable. And loader not offer me that option for choose which version want. No metter if is new or old. The same error.
    Tried to uninstall loader..used CCleaner for elliminate garbage, nothing.
  9. #10163
    Nov 2020
    Quote Originally Posted by mrben View Post
    @flyfvdi can you share the Source of VII Plus loader? not the compiled loader.
    Sent from my SM-G970F using Tapatalk
    no
    i do not have , sorry
  10. #10164
    Nov 2020
    Where i'm wrong?
    I will give you the VCDS Hex-V2 with main chip STM32F405VGT6 factory and manufacturer the technical support engineer contact mode
  11. The Following User Says Thank You to flyfvdi For This Useful Post:
    liviudiaconu (10th January, 2021)
  12. #10165
    STM32F415 doesn't support upgrade, only STM32F405...
    To resume :
    ATMEGA162 based cable -> Kolimer Loader
    STM32F405 based cable -> VII Plus Loader
    STM32F415 -> doesn't support upgrade
    Hope it help...
  13. The Following 2 Users Say Thank You to Creteil For This Useful Post:
    Col19 (11th January, 2021), ESPRIT (10th January, 2021)
  14. #10166
    Nov 2020
    Quote Originally Posted by Creteil View Post
    To resume :
    Hope it help...
    VCDS Hex-V2 with main chip STM32F405VGT6 is also available in the following languages:
    Chinese, Croatian, Czech, Danish, English, French, German, Hungarian, Italian, Polish, Portuguese, Romanian, Russian, Spanish, Swedish
  15. #10167
    Col19's Avatar
    Jan 2019
    France
    Hi friends
    I thank friend BADRAX for his development, please let us focus on helping BADRAX, I will take 415 just to participate and help BADRAX. I feel the new Kolimer, I take this opportunity to thank King Kolimer, the king of sharing, rare man.
    Thanks to everyone.
  16. #10168
    Nov 2020
    Quote Originally Posted by Col19 View Post
    Hi friends
    Thanks to everyone.
    STM32F415 is not enough good. there are many bugs. but we need the best tool to earn money。
  17. #10169
    Nov 2020
    STM32F405 + VII Plus Loader is the best vcds hex-v2. support update and multi-languages.
  18. #10170
    Jun 2019
    I have an atmega162 based V2 cable flashed and currently working fine with v19.6 and kolimer's launcher.
    What's the latest reliable version I can upgrade to?
  19. The Following User Says Thank You to Bastard2 For This Useful Post:
    da78n (26th April, 2022)
