Latest 20.12 is working, if you have atmega and kolimer loader. Uninstall 19.6 and install 20.12 use it with Kolimer loader. Tested.
Sent from my SM-G970F using Tapatalk
Col19 (13th January, 2021)
if you come from 19.6, i think you need to flash firmware with ewrite_lang, that you will find in loader 9.2 package.
VIIPlusLoader-08.021.01-EN-Installer.rar mega.nz download link:
https://mega.nz/file/FxkVxQgZ#Pknh_d...YwHSpDv1zxUTBU
Achtuhr (12th January, 2021), Aleks1975S (17th January, 2021), AYD (13th January, 2021), badrax (12th January, 2021), Col19 (13th January, 2021), Grind831 (20th January, 2023), H2Deetoo (28th February, 2021), jan4 (12th January, 2021), kaalis (12th January, 2021), liviudiaconu (12th January, 2021), Mario6 (12th January, 2021), mrle9 (13th January, 2021), Tib82 (13th January, 2021)
I have an old V1 Interface with Atmal 162 and I have been trying to figure out what software I need, but now I am confused.
I tried the VCDS 20.4.2 with VCDS Loader 1.22 but every time I press "Start VCDS" and choose the VCDS Software, the progam/window closed without any message, same under "Other Function" each Button pressed closes the software/window without any promt.
The Hardware is plugged in and has also 12V Power!
What is the latest VCDS version (German) I can use with the hardware?
What loader do I need?
Regards,
Jackson
you need Kolimer Loader 9.2, first try to update firmware with ewrite_lang.exw from Kolimer package then copy vcd$ loader to onstallation folder, make shortcut to desktop of vcd$ loader and it should work.
latest is 20.12, and is working with Kolimer loader 9.2
20.12 is in english, other languages not yet available.
and latest German VCDS Version for Kloader 9.2 ?
latest german version![]()
