Page 67 of 854 FirstFirst ... 1757626364656667686970717277117167567 ... LastLast
Results 991 to 1,005 of 12803
  1. #991
    Member ironderek's Avatar
    Problem solved, like bibkare said I had bad 805dump, with 908 works like a charm.
    So if I have 10.6 interface with FT232BL it can't be use at all with any 10.6 software? So why Chinese sell them with FTDI BL inside as 10.6 cable if it doesn't work?
    One more question, if I want to flash FTDI via FTProg is it enough change only extension from .ept to *xml or do I need convert it with some converter?
    Cheers.
  2. #992
    Oct 2008
    On Earth
    Quote Originally Posted by ironderek View Post
    Cheers.
    Chinese just sell, that's all, no meter what. With other wods they don't intrest in what they sell. They tell you what you want to hear. Not all of them but most do this in their deals.
    Just if you know what you need and ask precislly you have 90% chance to have what you ask. ( Do you've see that I didn' said 100%)
    To change the ept in in xml is not enought to change the extension.
    Aminebot said that in has this file but he dosen't share becasue one reason: "The Rules"
    So if he wants to share it is ok if he dosen't you can use MProg.
    Good luck
  3. #993
    DK Veteran bibkare's Avatar
    B & H
    Cheers.
    You can use your interface with 10.6 software if you flashed it (interface) with 10.6 dump ( same way you did with 908 dump), regarding ept file i did several times only changed extension but if high priest aminebot says it's not enough then i would listen him and finally chinese - they will tell you what you need to hear, in 99% cases that is far from truth, logic and common sense but wtf they are no. 1 economy in the world, so who cares as long as it's cheeeaaapp
  4. #994
    Thank you guys.
    Can you tell me what could be the problem if after connecting interface into USB port it doesn't show in Device Manager at all. After when I connect it into computer nothing happens, no any signs. Power goes true USB cable-checked it with multimiter.
  5. #995
    DK Veteran KenshinPT's Avatar
    PT
    Cheers.
    Hey... I just changed the extension and I never had a problem... I think =)
    But Animebot is the master... not me =) And if he says, I believe
    Did it help? Push Thanks below
  6. #996
    Aug 2010
    Quote Originally Posted by aminebot View Post
    Execute DPInst.exe in the attached archive. it contain 64x drivers.
    Attachment 48579
    Thanks, all work great!
  7. #997
    Oct 2008
    On Earth
    Thank you guys.
    Show us your Device Manager maybe the driver is UNKnown or uninstalled.
    Good luck
  8. #998
    Quote Originally Posted by KenshinPT View Post
    I asked because if I change only extension to .xml I can't program FTDI with FTProg. Ept file works perfect with MProg.
    Mattydr67 the problem is that nothing shows up in Device Manager. When I connecting cable into USB there is no sound and nothing is recognized over computer. If that will be drivers or unknown device I'll know how to fix it. But in this case looks like something is wrong with some PCB parts, mayby FTDI?
  9. #999
    DK Veteran rsibiza's Avatar
    May Usb Cable.
    I had some interfaces with brocken USB cables....
  10. #1000
    Mar 2009
    https://t.me/pump_upp
    Nice work guys. Thanks.
  11. #1001
    Feb 2011
    Trojan detected by Kaspersky after installing "VCDS-EN-9120-Installer-BETA.exe".
    The infected file is the "uninstall file".
    Beware.
    Thank you
  12. #1002
    Feb 2011
    Quote Originally Posted by ozzy_rp View Post
    Flash version 1.83
    Thank you
  13. #1003
    Feb 2011
    Thank you
  14. #1004
    Feb 2011
    Thank you! my English is not my strong suit. sorry!
  15. #1005
    Feb 2011
    Quote Originally Posted by xoom View Post
    Here is Sprint Layout 5.0 [with Update and Crack]
    and my made one side PCB for VAG-COM/VCDS[working 100%]
    im using it now
    bug founded on PCB.. need to exchange ATmega162 pin1 with pin2
    Nice place, Thank you for your contribution, thank you!
